Vent thingamabobs
Mar 6, 2008 | 09:23 PM
St. Jude Donor '08
Vent thingamabobs
The vent flapper that is inside the hole by the #2 body mount. The seals on mine are shot, anybody know their technical name and where I can find them to replace mine with? None of my catalogs show them.
Mar 6, 2008 | 09:25 PM
St. Jude Donor '08
no sooner than I hang the post out there and I find it. Sorry for the interruption!
BTW, it is a Fresh Air Vent Door Seal Rebuild kit.
Mar 7, 2008 | 08:51 AM
Just for future reference...where did you find them?
Mar 7, 2008 | 08:59 AM
Quote:
Originally Posted by
eileenthevette
Got mine from Doc Rebuild
Mar 7, 2008 | 09:14 AM
Thanks Jim!
Mar 7, 2008 | 09:55 AM
70BBvert
Me too. Drill out the rivets, new rubber, new rivets, done.
Mar 7, 2008 | 09:56 AM
St. Jude Donor '08
Corvette America and Zip both had them also.
Mar 7, 2008 | 12:09 PM
cool...This has been on my mind for over a year. Can you post pics?
Mine are a bit rusty and shot too.
Mar 7, 2008 | 12:55 PM
You can order them 'ready made' or go buy an 8"x10" sheet of black CRAFT FOAM at Michael's Crafts Store of Hobby Lobby. It is identical to the seal material used on that door. You still have to do the door disassembly, drill/grind out rivets, cut and install seal, pop-rivet back in place, paint if you want.
Mar 7, 2008 | 03:09 PM
OregonVette80
I have some pics on my machine at home. Bought a special tool to seat/crush the rivits. Used the same tool last weekend re sealing the heater box.
Jim
Mar 7, 2008 | 04:32 PM
St. Jude Donor '08
post a pic of the special tool for the rivets? What is it called and where did you find it?
Mar 8, 2008 | 08:18 AM
L82shark
I just used a punch to peen my new ones. They are pretty soft.
Mar 8, 2008 | 09:04 AM
Any chance of using pop rivets with washers on that?
Mar 8, 2008 | 11:12 AM
St. Jude Donor '08
markdtn
thats what I had planned on doing, the set I ordered comes with the rivets, will wait and see what type they are, otherwise I was just going to use regular rivets with a washer on the back and pound them flat!
Mar 8, 2008 | 11:47 AM
Please ckeck the cables that operate those doors, you may want to replace those too. Mine were trash!!!!
Mar 8, 2008 | 01:18 PM
Here's a pic of the completed doors
The tool is called a semi tubular rivet set. I found one that fits into an air
chisel. bought it from these guys. turn the air pressure all the way down as far as you can. The rivets are aluminum & will set very easily.
http://www.rivetsinstock.com/rivet62.htm
Jim
Mar 8, 2008 | 05:33 PM
astro vent doors
I re-did mine last week with the Doc Rebuild kit...no
problem and comes with detailed instructions.
The only door I found was the one on the passenger-
side footwell..there's another door somewhere?
Wondered why I had another piece of foam left over.
Where's the "other" ventilation door located??
HELP!!
Mar 9, 2008 | 07:48 AM
A72COUPEDT
HELP!!
Same place in the foot well on the drivers side
Jim
Mar 14, 2008 | 12:43 PM
St. Jude Donor '08
A72COUPEDT
HELP!!
Same thing here, only one vent that I can locate. So I guess I have a spare?
Mar 14, 2008 | 01:34 PM
I think AC cars just have one vent door.
I used pop rivets, no washers, worked great.
Steve
