DYNO's
Old Mar 7, 2008 | 08:29 AM
tomard's Avatar
tomard
Default DYNO's
For a guy that has never had one done, or seen one in person, what does it entail, are "they" all similar or much different depending on where you go?
What kind of information will it provide you, and does it take entire cars' driveline into equation, ie motor, diff, tires, tranny or ?
Maybe a dumb thread, but someday, when I think I am done with mods, I want to see what I have created (on paper) .... on the road it is evident ....
Also, where would I find reputable vendors in ones own home area (Alpharetta, GA) ?
Old Mar 7, 2008 | 08:33 AM
Durango_Boy's Avatar
Durango_Boy
Well there are a few types. There is an engine dyno, that tests output at the crank, as if it were connected to a transmission, only the Dyno is what it's connected to.
Then there is a chassis dyno. This is the one that the car drives up on, and is strapped down so the drive wheels are turning a large drum. This kind of test does in fact tell you your rear wheel HP and TQ at specific RPMs. It's a fantastic tool for tuning a car because you can make small subtle changes right on the dyno to see if they help on the next run. Things like timing, and mixture.
I have one here locally that I will use when I have my new engine finished and installed. If you have one locally, and use it, be prepared for a low number. Everyone always thinks they have more than they do until they get it done. It's shocking to a lot of people that have V8s, that they barely have 100 HP at the rear wheels.
Old Mar 7, 2008 | 09:07 AM
OzzyTom's Avatar
OzzyTom
I heard a quote a while back which rang quite true....
"there are lies... damn lies..... and then there's dyno results!"
Having said that.....
A dyno is a very good tool to assess and tune the power/torque at various revs and varying load conditions.
But there are many ways that the actual numbers indicated can be manipulated by the operator.... either intentionally, or unintentionally.
I see a lot of quoted figures of horsepower in signatures, and some of them raise my eyebrows.
In my opinion, there's only one true indicator of real world performance: a timeslip! Whether it's at the 1/4 mile or the track.
Use dyno numbers to assess the value of mods you do, but don't get caught up in the actual number of horses.
It's far better to look at your ET or trap speed at the end of the quarter mile, or your lap times at the track.
Here's a link to one of the most popular dynos in Australia...
Some pics and info for you to look at.
http://www.dyno.com.au/dyno/controller
Old Mar 7, 2008 | 09:08 AM
tomard's Avatar
tomard
Thanks Durango, well, the number, whatever it is, is at least a baseline .... as it stands now, I only know what the car came off the assembly line rated as, 28 years ago .....
What does your local dyno shop charge for the engine and/or chassis dyno, and how long does a typical run take?
Old Mar 7, 2008 | 09:18 AM
retroLS1's Avatar
retroLS1
Dynos are great tools for measuring the difference between power modifications. If I were you, I would get one done as-is right now at a local chassis dyno so you have a baseline for your car. Whatever you do from here on out, get it back on the dyno and see what kind of difference it made. Make sure to go to the same dyno, as pretty much all dynos read differently. DynoJet dynos read much higher than say, a Mustang dyno. Dyno Dynamics are pretty low as well. Like someone else said, go in there with low expectations and you shouldn't be too disappointed. Like OzzyTom said, your best idea of how much power you are making is a time slip from the 1/4 track. Trap times usually tell all, and will tell if the dyno is reading high or not.
I haven't looked up other dyno manufacturers' home pages, but here is one for DynoJet (one of the more popular ones). Click on the link, and then next to the Worldwide Search, use the menu where it says "Country (Including USA)" and select your state, Georgia. Hit Search and it will come up wit a list of all the places in Georgia that have a Dynojet, and you can contact them for more info. I have found the usual rate for a handful of runs on the dyno ranges anywhere from $50-100.
Old Mar 7, 2008 | 10:12 AM
captainmorgan's Avatar
captainmorgan
http://www.dynojet.com/dyno_centers/...utomotive.aspx
Old Mar 7, 2008 | 10:39 AM
retroLS1's Avatar
retroLS1
Oops! I knew I forgot something
Old Mar 7, 2008 | 11:48 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Visit the dyno shop's website (Used to work there) they have a lotta info about dyno's on there because they sell them too.
Old Mar 7, 2008 | 12:41 PM
S489's Avatar
S489
i've never been to a chassis dyno, so don't know how it should be done:
if car has manual, then the run is done in 4th gear (1:1), right?
if car is auto, what gear is used? if 3rd (or 1:1), how is downshift prevented?
--thanks
Old Mar 7, 2008 | 12:48 PM
retroLS1's Avatar
retroLS1
I have not dynoed an auto, but yes with a manual you want to use the gear closest to 1:1, which is usually 4th on a 6-speed and 3rd on a 5-speed. At least most shops I have seen use 3rd and 4th on the respective transmissions.
Old Mar 7, 2008 | 12:51 PM
SanDiegoPaul
--thanks
1:1 most times but it depends on the RPM range of the cam and your rear end gears.
If you've got 3:08 rear gears & an auto then they may use a lower gear if the cam revs you up into the 6's or beyond. Example:
My car does have 3:08s and the reworked Turbo 350 trans. We used high gear on my car and the speedometer still went well past 130 MPH on the dyno ... closer to 140
Not that the speedo matters, but what if I had a high revving mouse motor? My stroker maxes out at 5500RPM with the current Crane Cam. If they were stretching the RPM curve out to 6500 like in my old Nova, it may have pegged the speedo, who knows.
So if high RPMs are needed to get all the way through the power curve, then lower gears are possible. When I worked there, though high gear was the norm unless the car had an OD trans or a 5-6 speeed trans.
Old Mar 7, 2008 | 03:52 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Well here is my Dyno from 2 wees ago.... I have 77 L48 stock..
We have a monthly GTG at a local speed shop and they dodynos for 25.00 each and they even have a BBQ.......Very cool....
When I was there last there was a Cab.. Yes a cab on the dyno...it ran 185hp. and $7.50 on the meter.......LOLOLOLOL
[IMG][/IMG]
Old Mar 7, 2008 | 04:50 PM
L88Plus's Avatar
L88Plus
Unless you're a dedicated racer, the only one that really matters is the BUTT DYNO
Old Mar 9, 2008 | 03:32 PM
tomard's Avatar
tomard
Wouldn't it confirm that your motor was either tuned right (or incorrectly) if you were too far off from what you expected with your particular setup?
Old Mar 9, 2008 | 03:47 PM
worship79's Avatar
worship79
So how does one usually prevent the kickdown from working?
Old Mar 9, 2008 | 03:48 PM
tomard's Avatar
tomard
Went to website - and there is one right around the corner from me!!!! Shot them an email and probably swing by their shop tomorrow
To DYNO's
