Engine is pulled at last Now what?
Old Mar 8, 2008 | 07:51 PM
Wizziamrr's Avatar
Wizziamrr
Default Engine is pulled at last Now what?
Out, into the truck and off to the engine shop, after the snow storm! Akron Ohio got about 10" of snow today with drifts as deep as 3' so why not pull the engine today!!
Couple of questions;
Does all the emission crap have to be re-installed?
Will the on-boaed ECM function correctly if I don't hook up all the emissions stuff?
Old Mar 8, 2008 | 08:37 PM
derv3tt3's Avatar
derv3tt3
If its older than 25 years you don't need echeck.You might need a different distributer.What are you having done?
Old Mar 8, 2008 | 10:57 PM
Wizziamrr's Avatar
Wizziamrr
The engine had a knock in it at high RPM's, some opinions, wrist pin, main bearing and a few others.
Rather than try to diagnose it myself I decided to let an engine shop in Massillon tear it down and fix it. It is a L48 190 HP, I'm considering having it increased to 230 HP, L82 which is the other engine option for this year. Not sure if just a simple cam change is the thing to do or go for more HP.
Any advise is greatly appreciated.
Old Mar 9, 2008 | 09:04 AM
Durango_Boy's Avatar
Durango_Boy
More than just a cam. It's piston style too, as it increases the compression, and I think valve sizes in the heads.
Old Mar 9, 2008 | 11:05 AM
jbowles49's Avatar
jbowles49
Just curious, Why are you rebuilding the original? A crate motor would be much less expensive and better performer?
Good luck
Old Mar 9, 2008 | 11:57 AM
Wizziamrr's Avatar
Wizziamrr
Simply trying to keep the numbers matching for re-sale value. But that doesn't mean I have ruled out a crate motor as I will simply moth ball the orignal. Have you done this yourself ?
Old Mar 9, 2008 | 12:12 PM
jbowles49's Avatar
jbowles49
I purchased a 350/330 several years ago for replacement in a Chevy 2 that I own. I have been very pleased with every aspect of that process. Very nice performer with excellent street manners. My vette was a gift from my father and the original motor is still in good shape
Good luck
Old Mar 9, 2008 | 09:36 PM
derv3tt3's Avatar
derv3tt3
Have you decided anything yet?
Old Mar 9, 2008 | 10:44 PM
sperkins's Avatar
sperkins
If you're trying to keep it looking stock and keep the original numbers matching components in tact, I would at least consider a healthy cam and set of dome pistons to help w/ compression ratio. Other things to consider are:
Roller cam upgrade.
Roller rockers.
Double roller timing chain.
New balancer.
Old Mar 10, 2008 | 11:44 AM
derv3tt3's Avatar
derv3tt3
What year is your Vette?
Old Mar 10, 2008 | 12:18 PM
pbcanney's Avatar
pbcanney
wadsworth, medina, hinckley.... I'm really liking this house for sale in seville. looks like a good neighborhood to move to
the white one looks like 80/81
my son rebuilt the original in "ours" to a 383 after the timing gear jumped. If it were to need a second total rebuild, I'd be buying a crate.
Old Mar 10, 2008 | 10:00 PM
Wizziamrr's Avatar
Wizziamrr
1980, 190hp, TH350 Trans,
Old Mar 10, 2008 | 10:04 PM
Wizziamrr's Avatar
Wizziamrr
Granger, Seville is very nice ,still looks like country and easilly accessable.
Don't overlook Granger and Sharon Center, both are boarder by I77 & I71 with Rt 18 cutting thruough the middle to Montrose or Medina.
Thanks for your input!
Old Mar 10, 2008 | 10:10 PM
Wizziamrr's Avatar
Wizziamrr
Roller cam upgrade.
Roller rockers.
New balancer.
That sounds like a great option. I v'e seen some kits in the Summit catalog which is a twenty minute drive from here.
What about the ECM, will it run without all the emissions crap, or will I have to put on a new ignition?
Old Mar 10, 2008 | 11:01 PM
derv3tt3's Avatar
derv3tt3
What about carb,is it computer controled?
In spring and summer we have a Vette get together behind Burger King in Wadsworth.Not a club just a friendly get together around 6 til when ever,weather permiting.
Old Mar 11, 2008 | 11:15 AM
morleyz's Avatar
morleyz
I didn't think the '80 had the computer. I thought that was introduced in '81.
My opinion is to mothball and go with a crate. You might as well maximize your fun while you can.
And while you're deciding, you can take on that engine bay. Imagine how nice your new or rebuilt engine will look if you got it all cleaned up and painted.
Old Mar 11, 2008 | 09:36 PM
Wizziamrr's Avatar
Wizziamrr
Not sure but it may be. Spoke with Ollie Story of Story Motors of Massillon, He was very informative and did say that the ECM would not read the vacuum correctly on a new cam, but that maybe a chip could be changed to eliminate the problem. Also mentioned, as have many forum members that a new ignition system could run independent of the ECM.
I will sleep on all of the info from him and make a decision this week end as to what to do.
Wadsworth get together? Fridays, Saturdays ?
To Engine is pulled at last Now what?
Old Mar 11, 2008 | 11:53 PM
derv3tt3's Avatar
derv3tt3
Sorry I forgot its Tuesdays.You can pm me for my email address if you want. Some times we get together during the winter.But wait its almost spring.
Old Mar 12, 2008 | 06:08 AM
gingerbreadman1977's Avatar
gingerbreadman1977
your right the computer age started in 81. you have a very easy year to hop up. i would put your money into building what you have. if its a tear down job i would go a 383 kit. put some alloy heads on it.a nice roller cam. decent carb. msd ignition . new balancer by the look of it and a few other bling bits and pieces. get a 2500 stall and change your diff gears to 3.55 and your flying . a new crate motor is going to cost more than that and you still have your matching numbers and more space in your garage cause a moth balled motor wont be sitting there.while your at it degrease that engine bay. rust prime your chassis and paint it all up. should look awesome.
Old Mar 12, 2008 | 07:28 PM
derv3tt3's Avatar
derv3tt3
A 268 high energy cam 8004 Weiand intake hop up ignition and send carb to Lars.All this worked real well for me,but i also had better heads.
