Problem with hypercoil composite spring
Old Mar 9, 2008 | 09:22 PM
79tnvette's Avatar
79tnvette
Default Problem with hypercoil composite spring
Well after going with the composite after mixup with my new diff cover, I now have a new problem. I also got new bolts and a new plate to matchup with the 77prior cover and now the bolts wont line up with the holes in the cover. It seems that the new spring is just a smidge too wide causing the bolts to flare out missing the holes. I was wondering if anyone else had this issue. I believe I can take a dremel and notch out the plate sandwiching the spring enough to clear. Man it sure would be nice though for someone to make parts that actually mate up without modifiing them.
Old Mar 9, 2008 | 11:59 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
You must have the 2 1/2 wide spring used on 1978 and 1979 models. 77 and older use the 2 1/4" spring.
Old Mar 10, 2008 | 12:46 AM
79tnvette's Avatar
79tnvette
I thought of that but the composite springs should work on both and the box said 68-82.
Old Mar 10, 2008 | 12:23 PM
stinger12's Avatar
stinger12
Old Mar 10, 2008 | 01:22 PM
stinger12's Avatar
stinger12
To Problem with hypercoil composite spring
