underhood paint.
Old Mar 16, 2008 | 07:59 AM
stingray01's Avatar
stingray01
Default underhood paint.
Bought new sound deadening for underbonnet. I flatted underneath, gave it 3 coats of spray grey primer and 3 coats of matt black. After a couple of days the paint started to flake and peel back in 3 places exposing the bare surface. Any of you gents know what this could be.
Thanks .
Jamie
Old Mar 16, 2008 | 10:19 AM
retroLS1's Avatar
retroLS1
Did you use a high temperature paint or a regular paint? It gets hot under there so if it was regular paint, chances are it is just getting cooked off due to engine temps.
Old Mar 16, 2008 | 10:40 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I don't know if heat is the problem. I've used Rustoleum, black satin, several times and have never had this problem. I'd be more inclined to think the surface was not properly prepared/cleaned, especially with all layers of paint coming off so quickly.
Old Mar 18, 2008 | 05:58 AM
stingray01's Avatar
stingray01
I flatted with wet and dry underneath after removing the old paint, soap and water cleaning, dried off. 24 hrs later painted with grey cannister spray paint then matt black finish. Peeled back in a few places just like peeling an orange. Is there a special cleaner for fibreglass that you use in the states as it points to the fact that it was'nt clean in those parts. The hood is off the car.
Old Mar 18, 2008 | 06:33 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Mine is painted with regular black automotive paint with 2 coats of clear....no problems from peeling or anything.... Got rid of the insulation...
Old Mar 18, 2008 | 06:54 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i have normal 2 pac paint under my bonnet for 4 years and is as good as the paint on the top side of the bonet . you have a prep problem.
Old Mar 18, 2008 | 08:42 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Can we see some pics of the underside too.....
Id maybe to get an idea
Old Mar 18, 2008 | 10:50 AM
rponfick's Avatar
rponfick
Do you have an air conditioning? The spot above the AC compressor is infamous for absorbing oil slung off by the compressor. This can be very difficult to remove from the fiberglass.
Just something to check.
Ralph.
Old Mar 18, 2008 | 11:33 AM
gavanm01's Avatar
gavanm01
Got a stroked 496 with L88 hood and fresh air chamber, kinda crowded in there, but did the same as above. I don't miss the insulation, either. Might wish to check with a nearby body shop if they'll help with a suggestion.
To underhood paint.
