Help, stuck tail light lens!
Old Mar 18, 2008 | 08:45 PM
Rick Church
Guest
Posts: n/a
Default Help, stuck tail light lens!
My left rear turn signal light bulb is burnt out. I removed the two screws to pull the lens out but the top portion of the lens is stuck to somethiing, probably weather stripping. Are the two screws the only things that are supposed to hold the lens in place? I'm afraid to break the lens or chip the paiint by pulling or prying to hard. Recommendations..........
Old Mar 18, 2008 | 09:12 PM
wombvette's Avatar
wombvette
Take the screws out. Then stick a phyllips screwdriver of the proper size into the holes. Shake, wallow them sideways and pull out at the same time.
Old Mar 18, 2008 | 09:39 PM
sperkins's Avatar
sperkins
Old Mar 18, 2008 | 10:21 PM
CCrane65's Avatar
CCrane65
Well, actually, mine have three per lens. One in the center top and one on either side.
Your 71 shouldn't be any different.
cc
Old Mar 18, 2008 | 11:25 PM
LYLE's Avatar
LYLE
If you have an easy out that you twist to remove broken bolts put it in a T-handle and insert in the hole in the lens where the screw was and then turn it so it grabs the plastic and pull the lens off. If it is real tight move from one hole to the next till it comes off. No way this will sctatch the paint like a screwdriver will.
It has worked for me many times.
Old Mar 18, 2008 | 11:40 PM
7T1vette's Avatar
7T1vette
My '71 has 3 screws per lens. If the car has been repainted, the owner [or painter] may have installed them on top of some overspray before the paint hardened...that would make them tough to remove.
Old Mar 19, 2008 | 05:45 AM
redwingvette's Avatar
redwingvette
The bulbs come out through the back. Just twist the socket and it will come out. No need to pull off the lens.
Old Mar 19, 2008 | 10:21 AM
69monzacpe's Avatar
69monzacpe
Not on my '69, 3 screws, remove lens, remove and replace bulb. Does not come out from the backside. I believe '70 was the same Maybe newer vettes are different though.
Old Mar 19, 2008 | 10:48 AM
71rdster's Avatar
71rdster
68 - 73 are virtually all the same. Remove the lens to replace the bulb. 74 and up went to the plastic taillamp body with the twistin sockets.
Old Mar 19, 2008 | 03:57 PM
68/70Vette's Avatar
68/70Vette
Right, prying the lens off with a screwdriver will probably chip the paint---maybe covering the paint with masking tape will help. Next time you're looking at an Eastwood catalog looking for something to buy, check out their little nylon pry bars. It's a body shop tool for doing just what you'd like to do here ...pry out your lens. I think a set costs about $30 (?)
Old Mar 21, 2008 | 03:20 PM
Rick Church
Guest
Posts: n/a
Default I Must Be Blind!
I guess it was the angle I was working at, I never saw the third screw at the top of the lens. What a feaking dufus!
Old Mar 21, 2008 | 03:27 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Happens to the best of us.
To Help, stuck tail light lens!
