Help With Top Dead Centre
Old Mar 20, 2008 | 01:47 PM
Bowerss2's Avatar
Bowerss2
Default Help With Top Dead Centre
Hey all,
I had cylinder #1 at TDC before i took the heads, timing chain, and cam out. But my dad decided to rotate the engine over, for one reason or another. So i still have the timing chain, heads, and cam out, but #1 is not at TDC.
So what is an easy, idiots guide to getting it back to tdc when i put the timing chain and cam back in, i dont want to put it at tdc of the exhaust stroke is the problem. Cheers,
Steve
Old Mar 20, 2008 | 02:11 PM
lars's Avatar
lars
If the cam is out, there is no "exhaust" or "compression" TDC. Just bring the #1 up to TDC and you're there. The exhaust/compression stroke is determined once the cam and gears go in: You align the crank and cam dots so they both point straight up at the 12-o'clock position (NOT towards each other) to get the engine at TDC on compression.
Old Mar 20, 2008 | 02:47 PM
Bowerss2's Avatar
Bowerss2
hahaha ya i should have thought of that. Thanks Lars
To Help With Top Dead Centre
