head lights
Old Mar 20, 2008 | 09:10 PM
wary's Avatar
wary
Default head lights
my head lights dont go up can be the actuator ? what your guys recomend , fix the actuator or replace and , is to hard to fix?
pictures or diagrams are welcome. thanks for the help
Old Mar 20, 2008 | 10:53 PM
Dam's Avatar
Dam
6th Gear
I'm having the same problem, i'm waiting on your reply.....
Old Mar 20, 2008 | 11:27 PM
maddmickey's Avatar
maddmickey
Be sure you are getting vacuum where you need it. On my 74 I started where the vacuum line ran to the resivoir, then out to the relay, and then to the actuator. I had bad relays. You can test the actuator by pulling off a line that has vacuum and plug it into the front or back of the actuator. One line should raise it, the other should pull it back down. Good luck!!
Old Mar 20, 2008 | 11:34 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
pm me for diagram
To head lights
