Where can I purchase the correct temp sender for a '73 454?
All of the ones I've purchase so far result in high readings at the gauge (engine temp normal/much lower as per heat gun).
Thanks,
g.
another solution is to wire a resistor in line with the sender wire. go to radio shack a pick up a couple 5 ohm and 10 ohm 2 watt resistors for a few dollars. cut the sender wire close( not too close) to where it merges with the wire harness. temporarily wire one or more resistors in series with the sender wire until the engine and heat gun are close. solder everything and you're set. the added resistance to the circuit will reduce the relative voltage drop across the meter and will cause the meter to read lower temps. this won't be as accurate at very low or high temps( the senders aren't linear output) but if you set the resistors near working temps, it'll be close.
jeff
Thanks,
g.
George,
Try LectricLimited - they are the only ones who have the correct one for the '69 and I believe they cover most others.
Jack can explain it better, but basically, you will get an acceptable temp reading at a certain range of temps, but inaccurate readings out of this particular range.
G.
If you just put the required resistor in parallel with the sending unit, it will still be proportional throughout the gauge scale; if you put it in series with the sending unit, it will modify the scale, as it would never go to ambient temperature.
That's what I installed and no complaints - got it from them at a Corvettes at Carlsile show so I browsed their stock - they sell quite a range of these products....
as i stated in my original reply to geopar, if a resistor is wired in series with the sender, the low and high temps will be inaccurate (as are all the analog gauges on these 35 year old cars) but it will be close in the range that is used to set the resistance. i just think that it's a quick and easy fix.
jeff
jeff
i think Wilcox posted the following sensor resistances vs temp guage readings for our vettes:
220 degrees = 70 ohms
200 degrees = 90 ohms
160 degrees = 140 ohms
120 degrees = 250 ohms
100 degrees = 340 ohms
hopefully, i got that right
it would be interesting to compare the results of the resistor solution . . .
