1970 Corvette Owners Manual Question.
Old Mar 21, 2008 | 04:27 PM
1970CTU's Avatar
1970CTU
Cruising
Default 1970 Corvette Owners Manual Question.
As I understand it, there were 2 versions of LT1's in 1970 --- The early version CTU came factory equipted with 6 quart oil pans and the later versions CTK with 5 quart oil pans.
Were there 2 different owners manuals i:e: one which listed 6 quart oil capacity and later one listing 5 quarts ??????
Thank you.
Old Mar 21, 2008 | 05:03 PM
Alan 71's Avatar
Alan 71
CTU,
ROWDY RAT is the 70 LT-1 person around here. Perhaps he'll chime in. Interesting question!!
Regards,
Alan
Old Mar 21, 2008 | 06:41 PM
Duke94's Avatar
Duke94
The NCRS Tech manual says that CTU-coded engines have a larger oil pan than CTK coded engines. The smaller CTK oil pan allows clearance for install of power steering. Chevy records for the CTU-CTK changes are dated the end of April. The last CTU engine listed in the LT1 survey is s/n 8607. The first CTK is s/n 9021.
Old Mar 21, 2008 | 08:42 PM
1970CTU's Avatar
1970CTU
Cruising
Every 1970 Owners Manual that I have ever seen only specifies 5 quarts (with filter) for all 350 engines. --- If this is the case then owners of early 6 quart CTU LT1's would be down a quart even after a fresh oil change ?????????? That doesn't make any sense, there had to be a different manual or maybe a seperate instruction sheet to specify the correct crancase requirement ??????????? Hopefully some of the guys with CTU LT1's that still have their original Owners Manual will check into this. --- Thank you.
To 1970 Corvette Owners Manual Question.
