Help me start my restored 76
Old Mar 24, 2008 | 02:52 PM
Cruising91's Avatar
Cruising91
Default Help me start my restored 76
I have been restoring this car for 6 months now. I did not have the engine rebuilt as it has 48,000 original miles on it and ran great, but it was leaking and ugly so I took most of it apart to put in new gaskets and paint the components. My question is seeing how it hasnt run in some time should I pull the distributer and hook up a long flat head to a drill and turn the oil pump to circulate the oil first or am I ok to pull the coil wire off and just turn it over and circulate oil? Also I put in new fuel lines to the gas tank, should I syphon the gas up to the fuel pump or will the fuel pump pull the gas thru the empty lines just fine? Any other tips on starting a engine that hasnt run in 6 months would be appreciated. Here are some pics of the progress.
Old Mar 24, 2008 | 03:04 PM
jim2527's Avatar
jim2527
how long since its been turned over?
Old Mar 24, 2008 | 03:55 PM
Durango_Boy's Avatar
Durango_Boy
I think you'll be fine to just turn the key, and the time it takes to suck fuel up to the carb is all it'll need to circulate oil through the engine.
Old Mar 24, 2008 | 04:14 PM
Scott Marzahl's Avatar
Scott Marzahl
Just an FYI, a long bladed screw driver will not do anything to circulate oil throughout your engine, you'll need to use an old distributor to chuck up a drill to, or use a priming tool that blocks off the oil passages just as the distributor does.
Old Mar 24, 2008 | 04:23 PM
Cruising91's Avatar
Cruising91
ok, Ill just try and start it and see what happens.
Old Mar 24, 2008 | 04:26 PM
Cruising91's Avatar
Cruising91
its been 6 months since it has been turned over.
Old Mar 24, 2008 | 04:28 PM
bruced267's Avatar
bruced267
Why wouldnt a striaght type screw driver work? In a drill it would! Youd have to grind the gear off a old distributer shaft in oreder for that to work, other wise youd be trying to turn the valve train and motor!
I stand corrected! I was only thinking of turning the oil pump! You guys are correct. I use an old shaft with a modified gear
Old Mar 24, 2008 | 04:31 PM
Durango_Boy
The screw driver would fit the key way, but no pressure would build up. The bottom of the distributor, as well as the top part o the shaft, seal off the passages allowing the pressure to rise. You can spin a drill and a long screw driver all night long and oil might never get up to the lifters.
To use an old distributor you simply remove the gear from the shaft, and modify the top of the shaft to accept a drill and you're good to go.
Old Mar 24, 2008 | 04:46 PM
Cruising91's Avatar
Cruising91
I dont have an old distributer to modify so I will just try to start it. The carb is dry, should I pour a small amount of gas in it to help start it or just wait untill the fuel line fills and hits the carb?
Old Mar 24, 2008 | 04:47 PM
Durango_Boy
You will want a little bit of time before the engine starts, so leaving the carb dry will give the oil a chance to circulate.
That being said, how long has the carb been dry? The full six months? You might be looking at a carb rebuild if it wasn't rebuilt during the down time.
Old Mar 24, 2008 | 05:04 PM
Cruising91's Avatar
Cruising91
lars rebuilt it for me, just got it back and installed it about a month ago.
Old Mar 24, 2008 | 07:00 PM
7T1vette's Avatar
7T1vette
Just pull the distributor center wire and crank it over a few times to get oil on the bearings and in the galleries. Then re-insert the dizzy wire and fire it up.
Old Mar 24, 2008 | 07:38 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Mine sit for almost 6 months every winter & all I do is crank them over & drive! Nothing special.
To Help me start my restored 76
