Engine pad cleaning
Old Mar 25, 2008 | 05:16 AM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Default Engine pad cleaning
What paint remover can I use to remove the paint off my block pad. without damaging anything? I want to do this the safest way
Old Mar 25, 2008 | 08:19 AM
Durango_Boy's Avatar
Durango_Boy
Razor blade or sand paper, then spray some light oil to keep it from rusting.
Edit: If judges will be viewing it, I agree with below that less abrasive methods would be best. I thought you just wanted it visible for your own use and for pictures.
Old Mar 25, 2008 | 09:05 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You can also wipe it off with a little lacquer thinner. But don't get carried away with it. Just a little bit on a rag and just keep wiping the area until the paint is off.
Old Mar 25, 2008 | 09:24 AM
LYLE's Avatar
LYLE
Laquer thinner or paint remover. Do not scratch the pad with anything or you may make the broach marks hard to see and lose value to a purist buyer if the block is original.
Old Mar 25, 2008 | 09:41 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Dip a cotton swab in paint thinner and rub it over the surface. Follow it up with a clean rag.
Old Mar 25, 2008 | 10:00 AM
400hp427vette
St. Jude Donor '09
Thanks the block is date correct , I'm taking it to a ncrs judged show in may and the ncrs says that the pad must be clean
Old Mar 25, 2008 | 12:04 PM
LYLE's Avatar
LYLE
Originally Posted by 400hp427vette
Thanks the block is date correct , I'm taking it to a ncrs judged show in may and i say that the pad must be clean
No sandpaper for NCRS Clean with soft things.
Old Mar 25, 2008 | 12:26 PM
Chris Farrer's Avatar
Chris Farrer
Lyle is absolutely correct NO ABRASIVES, sandpaper or razor blades and alike.
Use a little thinners and mask the other areas off so you don't accidentally touch them with solvent.
Old Mar 25, 2008 | 01:04 PM
rihwoods's Avatar
rihwoods
Get a copy of the NCRS "1969 Corvette Technical Information Manual & Judging Guide"....I got one for my 78....lots of valuable info on "correct" paint,equipment,etc. specific toyour vette....plus points allowed/deducted....
Mine cost $35 at Barrett Jackson at the NCRS booth...
Good luck...
Rich
Old Mar 25, 2008 | 05:52 PM
400hp427vette
St. Jude Donor '09
Thanks for all the help I will let you know how the show goes. I hoping it will atleast score ok.
Old Mar 26, 2008 | 12:40 AM
Carl Granquist's Avatar
Carl Granquist
Default pad cleaning
I used DOT3 brake fluid on a Q-Tip, a wood tongue depressor cut square for scraping, then a soft clean cotton rag. Several cycles and there's still some orange in the letter/number recesses. A lot better than before though.
Old Mar 26, 2008 | 12:49 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...very nicely done...you can take a needle or pin to "carefully" get the paint out of the letters & numbers.
Old Mar 26, 2008 | 12:57 AM
Carl Granquist
Default later
Paul,
I took some grief from the wife when I was at the end of this little task last winter. Bless her heart, but she simply doesn't understand my Harley, the Corvette, or the time I spend with them. I'm ready for the final needle technique (thanks for the suggestion) but it'll probably happen just before some show this summer.
Aren't these cars great?
Old Mar 26, 2008 | 11:13 AM
wfo76's Avatar
wfo76
An old toothbrush and thinner will get the paint out of the numbers.
Old Mar 26, 2008 | 12:30 PM
yel76low's Avatar
yel76low
Acetone (and a q-tip).
Old Mar 26, 2008 | 01:59 PM
halfmoontrail's Avatar
halfmoontrail
Carb cleaner on a rag or q-tip
To Engine pad cleaning
