What should the normal operating oil pressure be? 5.7 Vortec motor, my gauge hits 50 when not in gear but goes down to about a little over 40 when on the road at 3,000 RPM. Is this low?
Thanks Eddie! After not driving her for close to a year, I forgot everything about her. Another thing, I transplanted a 4 speed in replacement of the TH350. I checked Corvette Central for speedo cables and they had 2 sizes for a 4 spd, which one should I get? The longer one or the shorter one?
From: Graceland in a Not Correctly Restored Stingray
A minimum of 10 psi per 1000 rpm (hot) is the target, so as long as you're seeing that much you're fine. What you don't want is excessive pressure (i.e.: 80 at 3000, as such only serves to waste power, load more heat into the oil, increase wear on the oil pump drive gears and dizzy bushings/bearings, and may open your oil filter bypass more often.
You have cruise control? That make a difference between cables...
I have a '71 with a 4 speed and recently replaced my speedo cable. You want the long one. I think it's 71 inches or something like that. I know it's in the 70's
John
If my pressure is reading 65 and up at 40-50 mph (72, auto, 350, disengaged tach), what can be done about it? I have always worried a bit about that and wondered what caused it, plugged holes?
Keep in mind that gauges aren't always accurate, so you might want to verify your pressures before making any drastic reduction. If your readings are correct, think about a lower viscosity oil (what weight you running now?) before anything else.
You don't happen to have an HP/HV pump, do you? That's an all too common cause. The standard pump is usually more than adequate for non-racing applications.
Oh, and go Tigers go!
I am running 10W40 oil now, and not sure what an HP/HV pump is. There is not smog devices if that is what it is. Thanks......and yes,,,,,.....KU Rocks! Hope they don't Roll!
You could go thinner, but I'd still try to check that your reading is on.
BTW, congrats to KU. Our guys obviously couldn't finish the job.
If your oil pressure is 50 at idle and lower than that at highway speed, you may have a problem with the pressure regulator circuit in the pump. With a HV pump, those pressures could be the same, but it shouldn't be lower at a higher RPM. If yours is a stock pump, idle pressure should be in the 10-20 psi range at idle.
