Alternator working?
Old Apr 7, 2008 | 09:02 PM
damlie's Avatar
damlie
Default Alternator working?
Other than waiting to see if my battery completely fails on me is there any way to tell if my alternator is working? I replaced the old bolts on the casing this weekend and now I'm having a few odd electrical glitches (eg: radio cut off a couple times, turn signals dimmer than normal, etc), so it's got me worried.
Old Apr 7, 2008 | 09:17 PM
croaker's Avatar
croaker
Take a screwdriver and touch it to the bushing on the back of the alternator it should have a magnetic pull or pull it off and bring it to the Auto Zone or any of the other stores who check them the screwdriver method has always worked for me
Old Apr 7, 2008 | 09:24 PM
damlie's Avatar
damlie
I'm assuming the car has to be on for this to work right?
Old Apr 7, 2008 | 09:30 PM
sperkins's Avatar
sperkins
Why not just check it with a volt meter?
Old Apr 7, 2008 | 10:19 PM
comp's Avatar
comp
first test ,, then a load test
Old Apr 8, 2008 | 12:16 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That's why there's an electrical meter in the dash...
Old Apr 8, 2008 | 08:47 AM
GaryS's Avatar
GaryS
Whoa! I wouldn't be doing that unless you want to risk damaging your alternator. Why not go to Home Depot/Lowes and buy a $10 multimeter. Put it on DC and check the voltage at the battery. With the engine running you should have 14.3 +/- volts. Off it should show 12v. Or, do what the poster suggests in the second half of his suggestion. By buying your own multimeter, you will then have it for future use.
Gary
Old Apr 8, 2008 | 09:42 PM
croaker's Avatar
croaker
yes
To Alternator working?
