How much PSI?
Old Apr 8, 2008 | 11:39 PM
C7GrandSport's Avatar
C7GrandSport
Default How much PSI?
The '73 454 I just bought has Goodyear Eagle GT II's. Tire placard on door says to run 20 PSI. That seems pretty low. What do you guys with radials run on your C3's?
Old Apr 8, 2008 | 11:46 PM
Steve COSD's Avatar
Steve COSD
I have 255 15R60. I put 32 cold and works up to 34 hot.
Old Apr 8, 2008 | 11:47 PM
auctionman256's Avatar
auctionman256
32 Psi
Old Apr 9, 2008 | 12:05 AM
Solid LT1's Avatar
Solid LT1
Rule of thumb about 1 psi for 100LBS of weight of auto. Your 454 Vette weighs around 3500lbs so 32-35 PSI should get you in the ballpark.
Old Apr 9, 2008 | 01:35 AM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Thanks I will Use that rule of thumb
Old Apr 9, 2008 | 08:32 AM
C7GrandSport
What was so different about the OEM radials that such low tire pressure was recommended by GM?
Old Apr 9, 2008 | 08:42 AM
1Sweet66's Avatar
1Sweet66
In '73 I'm pretty sure that they were coming off the line with bias ply tires. I may be wrong. But that would be a whole different type of tire.
BTW I run 32 psi in my BFG 245's. /:\
Old Apr 9, 2008 | 09:53 AM
C7GrandSport
1973 was the first year for radials on a Corvette.
OEM on my car was option "QRM GR70 x 15 steel belt radial w/s" for $32
(Yes, I have the original window sticker)
Old Apr 9, 2008 | 10:23 AM
NHRalph's Avatar
NHRalph
Biased ply tires ran a little lower, usually 26 to 28 pounds. The 20 pounds on the sticker was so the ride would of been softer.
Old Apr 9, 2008 | 11:34 AM
7T1vette's Avatar
7T1vette
Actually, radial tires ran lower pressures than bias-ply tires. That is because the 'footprint' of an equivalent radial tire had larger area than the bias-ply tire. It is a matter of filling the tire to obtain its designed 'shape' while supporting the car's weight. In general, early U.S. radial tires were underinflated by manufacturer specs, and early radial tire failures proved that out. Proper tire pressure should be in the 28-32 psi range. Lower pressure will yield a softer ride; higher pressure will yield better stability [but firmer ride and less tire life].
To How much PSI?
