Adhesive question
Old Apr 9, 2008 | 11:01 AM
Saint's Shark's Avatar
Saint's Shark
Default Adhesive question
I am going to replace the "crossed flag" emblem on my L-82 valve cover. What's a good high temp adhesive to use?
Old Apr 9, 2008 | 11:26 AM
Durango_Boy's Avatar
Durango_Boy
I think a good epoxy would do the trick. You can get many different variations. I prefer clear, and the five minute epoxy will let you take your time to mix, apply, and set the emblem before it hardens.
7T1vette's Avatar
7T1vette
If that part was originally 'glued' on, the new part should be adhesive backed or come with an appropriate adhesive. If it doesn't, I wouldn't buy it.
Old Apr 9, 2008 | 01:16 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I just used a dab of silicone.
Old Apr 9, 2008 | 01:30 PM
Trae1976's Avatar
Trae1976
High-temp gasket maker should work.
Old Apr 9, 2008 | 07:01 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
I put mine on with double sided tape (3M). That was in 2001. They are still on the car.
Old Apr 9, 2008 | 07:50 PM
GlockGuy's Avatar
GlockGuy
after all, silcone is an "adhesive" and can be removed if necessary. I have always been amazed at what good ol' silcone will glue and hold permanently.
Old Apr 9, 2008 | 07:57 PM
Dirtbuster1's Avatar
Dirtbuster1
You can also buy the black double sided adhesive that looks like 1/8" rubber. Go to a paint supply store to see what they have.
Old Apr 10, 2008 | 12:37 AM
stingr69's Avatar
stingr69
JB weld epoxy.
-Mark.
Old Apr 10, 2008 | 12:56 AM
1981Z06Vette's Avatar
1981Z06Vette
Gorilla Snot works great (3M Weatherstrip Adhesive). I glued the emblem on a C4 valve cover with it once, and it stayed put with no problem. You can get it in black, too.
To Adhesive question
