Best Body Adhesive
Old Apr 9, 2008 | 05:01 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Best Body Adhesive
I'm about to re-attach the front clip to the body on a 73. What is the best body adhesive being used today?
In the past I used some stuff from 3M which worked ok but it seemed to set up pretty fast.
Advice welcome!
Old Apr 9, 2008 | 05:06 PM
sperkins's Avatar
sperkins
FUSOR.
http://www.lord.com/Home/ProductsSer...1/Default.aspx
Old Apr 9, 2008 | 05:10 PM
Artsvette73's Avatar
Artsvette73
Originally Posted by sperkins
They have diffrent working times and the gun is about 65.00
Old Apr 9, 2008 | 05:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Evercoat's panel adhesives come in different working times and can be used in a regular caulk gun. They worked fine for me when I installed half of an inner fender and re-attached the outer fender to the inner structure.
Old Apr 9, 2008 | 05:37 PM
JonnHeather's Avatar
JonnHeather
3M 8115. Excellent working time and incredibly strong. This is also corrosion resistant so if you bond metal to fiberglass you don't need to worry about rust...
Old Apr 10, 2008 | 07:55 AM
tomply32's Avatar
tomply32
Default bonding adhesive
we use a combination of adhesives depending on situation.8115 from 3m we use to bond fronts and inner panel this is what you need it gives you about 90 minutes of working time .also sem products has adhesives that work well just hard to find sometimes.evercoat panel adhesive we use to bond fenders and quarters or any where a bonding seam is visible (sets up fast so you have to be quick).i dont like to put polyester glass over any 8115 (just my opinion)it does set up fast.
Old Apr 10, 2008 | 11:31 AM
temvette72's Avatar
temvette72
I used FUSOR. It worked great, had plenty of working time, but it is expensive and the Devil to clean up (wear gloves!).
Temvette72
Old Apr 10, 2008 | 11:18 PM
73, Dark Blue 454
3M's 8115 is what I believe I've used before but I don't recall a 90 minute time frame,..more like 20.
I'll give it another shot since I'm familiar with the product.
Thanks for all the great advice!
Old Apr 11, 2008 | 12:03 AM
hwcoop's Avatar
hwcoop
I used the same when bonding my front fender and header panel reinforcement...stuff is tough as nails once it sets and price was reasonable too
Old Apr 11, 2008 | 07:13 AM
BB72's Avatar
BB72
Fusor gets as hard as rock. Get the gun with Fusor because the gun mixes the stuff in the nozzle and you can put it right on the clean bonding surfaces. Definately worth the $40 for the gun.
Old Apr 11, 2008 | 08:13 AM
vettesbydesign's Avatar
vettesbydesign
I have used Fusor w/great results,and I use SEM non-sag/structual adhesive,and have for a long time.I just recently used the Evercoat,and for some reason was uncomfortable w/it,popped the clip back off,and redid the whole thing w/what I knew,and use.I use the paint stores loaner gun,and I mix mine on a bondo board,then put it on w/a spreader.......Make sure you scuff everything w/a grinder on the inner front end where the bonding strips will come into contact,and make sure that the bonding strips are clean,and free of past adhesive.
Old Apr 11, 2008 | 08:39 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Evercoat's adhesives work the same way - there are two chambers in the tube which are mixed in a "maze" type nozzle.
Old Apr 11, 2008 | 08:48 AM
mzmgb's Avatar
mzmgb
Stuff is great. I received a free gun with my purchase.
SEM Paints SEM39337 Non-Sag SMC Structural Adhesive
Old Apr 11, 2008 | 08:01 PM
jimiscnc's Avatar
jimiscnc
Default Question
Anybody use Fusor without the $65 gun? just squirt the two tubes out and stir it together ?
I'm too cheep to get the gun!
thanks
Jim
Old Apr 11, 2008 | 08:40 PM
zwede's Avatar
zwede
We used marine-tex to bond the panels on mine. No special gun.
Old Apr 12, 2008 | 12:33 AM
MixxMaster's Avatar
MixxMaster
I used Fibertech from Evercoat. It worked great. No gun or special tools needed. It has Kevlar fibers in it, making it strong as hell...
To Best Body Adhesive
