Why would a vette lean to one side ?
Old Apr 12, 2008 | 02:56 PM
Spitfire80's Avatar
Spitfire80
Default Why would a vette lean to one side ?
Gents...
My brother just purchased an '81 Vette.
Now in his garage(levelled), we noticed that the car is leaning on the driver's side, front and back.
We took precise measurement and we're talking an 1.5 inch lower than the passenger side.
What can cause this and what to do to fix it ?
Input anyone ?
Phil
Old Apr 12, 2008 | 03:09 PM
72LS1Vette's Avatar
72LS1Vette
Depends on where you measured the body. If the frame rails are 1.5" different look at the suspension and frame for signs of worn, broken, or damaged parts. If the frame is level and the body itself is off-level, I'd suspect that the body mounts are worn out.
Rick B.
Old Apr 12, 2008 | 03:28 PM
vettesbydesign's Avatar
vettesbydesign
It's a vett!!!!I thought they all leaned?Check your susp.,but many do lean.That's just the way it is.
Old Apr 12, 2008 | 03:33 PM
Spitfire80's Avatar
Spitfire80
Default Uhhhh ?
Lean yes, but not even !
We step back away from the vette and looked at it from behind.
Its leaning lower on the driver's side...
Phil
Old Apr 12, 2008 | 04:24 PM
JBristow's Avatar
JBristow
Ask your sister-in-law to get out of the car and remeasure.
Old Apr 12, 2008 | 04:31 PM
Spitfire80's Avatar
Spitfire80
Default If you only knew....
If ya only knew what she looks like....
You wouldn't want her to step out I guarantee you !
Old Apr 12, 2008 | 04:40 PM
Jim_Harrison's Avatar
Jim_Harrison
You might also try measuring the spring flex by measuring both the Driver and pass sides, the distance between the A-arms and on the rear by measuring the end of the spring on both sides to the frame. That might give you an indication of a bad spring?
Old Apr 12, 2008 | 05:47 PM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
You didn't!!
Old Apr 12, 2008 | 07:08 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Maybe a fat guy used to own it and fatiged the springs on the drivers side.
Old Apr 12, 2008 | 07:12 PM
nutsy's Avatar
nutsy
LMAO
Old Apr 12, 2008 | 08:48 PM
sperkins's Avatar
sperkins
Hmmm. Mine does the same thing.
Old Apr 12, 2008 | 09:29 PM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
That's easy, because they are COOL
Old Apr 12, 2008 | 11:04 PM
OzzyTom's Avatar
OzzyTom
Maybe this girl was the previous owner... ?
Old Apr 13, 2008 | 01:51 AM
marshrat99's Avatar
marshrat99
Gents...
Input anyone ?
Phil
Back to the question, springs or body mounts.
Old Apr 13, 2008 | 02:55 AM
Jclgodale3's Avatar
Jclgodale3
neither...flawed GM body mold
Old Apr 13, 2008 | 08:46 AM
vettesbydesign
I need to start getting some kinda proceeds w/my wife's,and my picture being shown all over the internet! Personally,and just ask my mother....I think we make a lovely couple!!!
Old Apr 13, 2008 | 09:10 AM
jdp6000's Avatar
jdp6000
Are you on level ground? Turn the car around. Does it still lean on the same side?
have you had that one side jacked up recently? it will sit down eventually.
Jim
To Why would a vette lean to one side ?
Old Apr 13, 2008 | 10:00 AM
82cruiser's Avatar
82cruiser
Jim
Jim pm sent, sorry for the hijack
Old Apr 13, 2008 | 10:03 AM
Mewn's Avatar
Mewn
Frame mounts!
Old Apr 13, 2008 | 11:51 AM
Ironcross's Avatar
Ironcross
Then you might consider moving over to her side getting straight to the point and leveling things out...
