C3 Door Hinge Spring Installation Tool
Old Apr 13, 2008 | 06:14 PM
Thmprr's Avatar
Thmprr
Default C3 Door Hinge Spring Installation Tool
I have read during a search that you can't install new C3 Door Hinge Springs without a C3 Door Hinge Spring Installation Tool.
Problem is I don't have one, and in New Zealand you can't get things like this over night.
I have seen photos of one and using scaling it looks as though it's about 12" long, 3/8" shank bent about 45 deg at the 2" point.
Can someone who has one measure theirs, and check if these measurements sound about right?
This minor job is driving me
Old Apr 13, 2008 | 06:33 PM
wombvette's Avatar
wombvette
Its just a screwdriver with about a 45 deg. bend and the blade end rounded a little bit. A torch and a vice will make one up in a jiff.
Old Apr 13, 2008 | 06:35 PM
72LS1Vette's Avatar
72LS1Vette
Here is a pic of the tool. It is just a bent screwdriver but the angle and position of the bend are exactly right for installing the door spring.
Rick B.
Old Apr 13, 2008 | 06:45 PM
Gordonm's Avatar
Gordonm
I heated up the tip of a screwdriver and bent it to the needed angles. Very simple and it was an old screw driver anyway. Just a torch and some plyers and a vise will fix you right up.
Old Apr 13, 2008 | 07:13 PM
Durango_Boy's Avatar
Durango_Boy
Does anyone have any pics of the tool being used to remove springs?
Old Apr 13, 2008 | 07:25 PM
Thmprr's Avatar
Thmprr
Rick B.
Thanks Rick
That's exactly what I need, that's what is so great about this forum, it's like having hundreds of best mates living next door to ask for help.
To C3 Door Hinge Spring Installation Tool
