Engine mounts?
Old Apr 19, 2008 | 04:38 PM
agent kronus's Avatar
agent kronus
Default Engine mounts?
I got my old engine out today, without any problems!
so I want to use new mounts for the new engine, which ones should I go for? standard ones for my 78 from zip or poly's??
cheers
dave
Old Apr 19, 2008 | 07:10 PM
Durango_Boy's Avatar
Durango_Boy
I went from stock to solid and really like the change in rigidity.
Old Apr 19, 2008 | 07:11 PM
agent kronus
is there more vibrations through car from engine?
Old Apr 19, 2008 | 07:14 PM
Durango_Boy
Nah not too bad. If I really concentrate I can feel them but if I don't look for them I can't tell. No one that rides with me detects any vibrations either.
Old Apr 19, 2008 | 09:10 PM
Doug70vert's Avatar
Doug70vert
From: Part breakage is just weakness leaving my Stingray
I went with poly. I can't say that I can really tell a difference, but I figured if I was replacing them, I might as well upgrade.
Old Apr 19, 2008 | 09:39 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
If you get stock ones, don't buy any in a Corteco Mountec or ROL Manufacturing box. I work for Corteco and this week I tried installing a set of our mounts on my car. I hate to badmouth the company that puts food on the table but they didn't fit. I fought with them for 2 evenings (about 4 hours total) trying to get the bolt holes to line up. I gave up and went to NAPA and got another set. In a half an hour, I had the bad mounts out, the NAPA ones in, and everything bolted up.
Old Apr 19, 2008 | 10:33 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
I havent noticed any noticeable increase in vibrations either.
Old Apr 20, 2008 | 01:21 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I have a set of chrome/red Energy Suspension polys around here, never installed. After Norval and several other tech gurus here raved about the solid mounts, I went that way and never looked back.
Old Apr 20, 2008 | 04:27 AM
agent kronus
would these suit?, easy fitting, lining up holes for engine install?
http://www.zip-products.com/Zip/prod...9C1CA0AC4E1692
cheers
dave
Old Apr 20, 2008 | 12:35 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
ES is what I used on my car, no installation problems at all.
To Engine mounts?
