Bearing Clearance
Old Apr 20, 2008 | 01:19 PM
hgm's Avatar
hgm
Default Bearing Clearance
Getting ready to install the crank in my 383 build. Main bearing clearance with Plastic gauge is between .0015 and .002. To tight? Good to go? Thanks, George
Old Apr 20, 2008 | 02:12 PM
A88FXRS's Avatar
A88FXRS
that will work. check crank rotation for block or cam interference. check again with rods on. good luck
Old Apr 20, 2008 | 04:35 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Sorry to disagree, but IMHO anything less than 0.002" is just too tight, and you could end up having to run such thin viscosity oils to keep pressures within reason as to create other problems. You can gain 0.0005" by using 0.001" thinner upper shells in the rods or lower shells in the mains, which would put you in the 0.002-0.0025" range. Don't consider the leftover shells as a waste, rather a small price for doing this right. Oh, and don't mix brands.
Old Apr 20, 2008 | 08:15 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
.001" for every inch of crank journal diameter for a street motor
Old Apr 20, 2008 | 09:24 PM
hgm's Avatar
hgm
When I read the caps they matched the .002" marks. The crank had wider areas falling between .0015 and .002. How reliable is plastic gauge? Should I have it checked with a set of mic's? Thanks
Old Apr 20, 2008 | 09:26 PM
MotorHead's Avatar
MotorHead
I would not build a motor with plastigauge, you need a dial bore gauge and mics to do it properly
Old Apr 20, 2008 | 09:55 PM
billla's Avatar
billla
St. Jude Donor '14
x2
Old Apr 20, 2008 | 10:37 PM
682XLR8's Avatar
682XLR8
If you don't have access to these tools, take the block/crank/rods to a machine shop and have them mic it, well worth the added $$
Old Apr 21, 2008 | 12:08 AM
billla's Avatar
billla
St. Jude Donor '14
I've built a number of OEM engines over the years with plastigauge and found it an acceptable CHECK for a machine shop that you know can hold a clearance.
For any type of performance engine, it's not enough I agree. As a side note, cheap micrometers and a set of snap guages are better than nothing. In my experience, these work well if kept calibrated. I have a real el-cheapo set I got at a swap meet that I use on my bench, and they've really held up quite well. The economy bore gauges are close enough as well until you get into big-dollar engines. All IMHO, of course
http://www.goodson.com/store/templat...b58fc626f7732e
To Bearing Clearance
