Dash lights....
Old Apr 20, 2008 | 08:33 PM
Spitfire80's Avatar
Spitfire80
Default Dash lights....
Gents
1980 Vette
Installed new dash.
Reinstalled the speedo & Tach and plugged in accordingly.
Also installed a new lightswitch.
When I turn on the lights, there's no dash lights coming on. Is it because my center console bezels are not installed yet ?
I need to know before goin' further....
Where should I start looking ?
Phil
Old Apr 20, 2008 | 09:03 PM
'75's Avatar
'75
I would start with the fuse. Also make sure the switch is turned to the left for brighter dash lights. It shouldn't make a difference that the center is still out.
Old Apr 20, 2008 | 10:24 PM
Spitfire80's Avatar
Spitfire80
Default Reading and searching for tips and answers...
Used the SEARCH tool and read some threads...
Don't have much knowledge when it comes to ELECTRICAL stuff:o
Which FUSE is it in the panel ?
Is it indicated ?
Please someone help me man
HEADLIGHT switch is new $130can
Phil
Old Apr 20, 2008 | 10:29 PM
'75's Avatar
'75
On my 75 there is printing just below each fuse telling what it is. On mine the shortest fuse is for the dash lights, a 5 amp. If you have a test light, turn on the lights then test on each side of every fuse till you find the bad one.
Old Apr 21, 2008 | 07:57 AM
Durango_Boy's Avatar
Durango_Boy
I got our PM and came looking for the thread. As mentioned above the fuse panel should have the fuse positions labeled. I seem to remember the dash lights being on the same circuit as the clock and cig lighter.
I wish I were better at these electrical gremlins. I have a big one of my own that's really starting to frustrate me. Sorry I can't be of more help.
Old Apr 21, 2008 | 08:52 AM
jdp6000's Avatar
jdp6000
You want to check the 20 amp guages fuse and the 20 amp CTSY-CLK fuse. The important one is the instrument LPS fuse (this is the fuse the instument lights are powered through). Its 7.5 amp and at the top of the board.
Jim
Old Apr 21, 2008 | 11:34 AM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
on my 79 recently, i had to get ALL lights fuses working before the dash would work, so double check allllll light fuses
Old Apr 21, 2008 | 02:10 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
There is a website that has the GM electric diagrams for 1980 Corvettes. I've tried searching and can't find it. Hopefully someone here has the link saved and can post it.
To Dash lights....
