Motor mount bolts
Old Apr 20, 2008 | 11:06 PM
70 LS1's Avatar
70 LS1
Default Motor mount bolts
What size bolts attach the motor mounts to the frame?
Old Apr 20, 2008 | 11:46 PM
chevr0letman's Avatar
chevr0letman
i just swapped mine out and i used 1 inch grade 8 3/8's bolts. worked fine
Old Apr 21, 2008 | 01:22 AM
70 LS1's Avatar
70 LS1
I think you are thinking of the bolts that attach the mounts to the block. I am looking for the bolts that attach the mounts to the frame.
Old Apr 21, 2008 | 02:36 AM
Solid LT1's Avatar
Solid LT1
7/16-14 NC by about 4.5" long and the factory bolts have a tapered threaded end to allow them to be BEAT through the motor mounts when installing. Don't forget the locking nuts that are on the OEM bolts (called Stover Nuts.)
Old Apr 21, 2008 | 05:42 PM
70 LS1's Avatar
70 LS1
To Motor mount bolts
