Diff and crossmember removal
Old Apr 21, 2008 | 07:39 AM
Simmo's Avatar
Simmo
Default Diff and crossmember removal
Im removing the diff and figure I would do it with the crossmember. Everything is unbolted, but when I lowered the jack holding it up it stayed secured. Does the crossmember often stick? What is the best way to separate it?
Old Apr 21, 2008 | 07:40 AM
Durango_Boy's Avatar
Durango_Boy
Crowbar.
Old Apr 21, 2008 | 09:53 AM
crf311's Avatar
crf311
Spray with PB Blaster and let soak. Use a 2 lb hammer , and with low impack hits, hit around where the crossmember is attached. Then a small crow bar may help. Took me a couple of days of spraying and hitting, then it fell off. Don't beat on it , just low impack blows, will do the job.
Old Apr 21, 2008 | 10:26 AM
427-390's Avatar
427-390
You may also consider using a gear puller if the pry bar method does not work. My crossmember popped off without too much effort. Be advised: leave the bolts semi-threaded on the crossmember and to keep a jack under the differential when doing this. Good luck.
Old Apr 21, 2008 | 11:42 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
easiest way is to come in with a crowbar from the wheel well, it will pop right off. Make sure it is supported as said earlier!
Old Apr 21, 2008 | 12:41 PM
JP_80's Avatar
JP_80
I just took mine off this weekend. I sprayed it down with PB Blaster everyday this week when I got home and then Saturday morning I used a crowbar (from wheel well) and it popped off just using my body weight, no hitting, pounding, etc.
Old Apr 21, 2008 | 12:49 PM
another-user's Avatar
another-user
i used a gear puller on mine. had it off in about 15 mins.
Old Apr 21, 2008 | 12:53 PM
BB68Vett's Avatar
BB68Vett
I used a 5 ft. crowbar.
Old Apr 21, 2008 | 01:15 PM
CaptainHook's Avatar
CaptainHook
I used a 3 jaw gear puller. Popped it out without a sweat.
Old Apr 21, 2008 | 04:44 PM
GTR1999's Avatar
GTR1999
I would suggest using the other methods before the puller. Most times it won't be a problem but it could loosed the spot welds on the sombero and that could lead to other issues.
The bar usually works or wedges.
Old Apr 21, 2008 | 05:45 PM
Simmo's Avatar
Simmo
Thanks for all the help. Lots of good ideas.
I hope its easier to get out than the trailing arm bolts, now that was a job.
Old Apr 21, 2008 | 06:08 PM
another-user
as much as i liked using the gear puller, it did have its downsides, like GTR mentioned.
this happened yesterday when i pulled mine off with the gear puller.
i dont think any amount of pushing or prying was going to break it free though.
To Diff and crossmember removal
