baby leans left
Old Apr 23, 2008 | 07:23 PM
ndmick's Avatar
ndmick
Default baby leans left
Noticed my baby leans to the left at the rear.Going to get under this week end and see what I can find,any ideas?It leans about 3/4 in at rear wheels ,to the left, at a quick glance under there all looks preety new.(71 with a small block) I have noticed when I put in gear it drops down in rear,maybe rear spring worn out? bushings look new.
Old Apr 23, 2008 | 07:30 PM
Durango_Boy's Avatar
Durango_Boy
All Vettes leaned a little bit. Get some baseline measurements. Go all the way around to each fender wheel opening, and measure ground up. Then measure ground to frame, and compare to see if it's the body on the frame that is off, or the car off the ground that's off.
Old Apr 23, 2008 | 07:32 PM
ndmick's Avatar
ndmick
did a quick trip seams like frame square to ground but body leans left n rear only.everything in suspension looks in good shape almost new.
Old Apr 23, 2008 | 10:32 PM
Jclgodale3's Avatar
Jclgodale3
typical
Old Apr 23, 2008 | 10:38 PM
Glassbowtie77's Avatar
Glassbowtie77
Check your body mounts.
Old Apr 23, 2008 | 11:55 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree on the body mounts and mounting could be rotted. Also, one of the leafs in the rear leaf spring could have broken on one side.
To baby leans left
