popping!!!!
Old Apr 23, 2008 | 09:14 PM
DINO XANTHAKYS's Avatar
DINO XANTHAKYS
Default popping!!!!
My engine is backfiring and popping when I take my foot off accelorator? I made it richer but still backfiring.
HELP? Is there a limit to how rich I can make it?
What else can it be?
Thank you!!!
Dino
More info:
75 l48 350 all stock exept edlbrock performer manifold with stock qjet and 2 1/2 inch true dual to twochambered flowmasters.
This just started happening, on deceleration. I made the carb richer with the dial on the passanger side of the carb.
Thanks DINO
Last edited by DINO XANTHAKYS; Apr 23, 2008 at 11:40 PM. Reason: Sorry here is some more info>>>
Old Apr 23, 2008 | 09:48 PM
rihwoods's Avatar
rihwoods
Timing...ignition...???
Old Apr 23, 2008 | 10:57 PM
corvette744's Avatar
corvette744
WTF give us a little more info.What engine,what carb.How did you make it richer.WHen did it start doing this.DId you buy it that way,or just started doing this.
Old Apr 23, 2008 | 11:48 PM
DINO XANTHAKYS
Default Some more info
This just started happening, on deceleration. I made the carb richer with the dial on the passanger side of the carb It reduced it but not much. Could the carb be screwed up or the ingnition/ timing.
This weekend I am going to change the plugs, the ones on the engine have only about 2,000mls on them.
Thanks DINO
Old Apr 23, 2008 | 11:58 PM
corvette744
Great better explanation unfortunately im a holley man inside and out.I dont think i can help with the q jet.But i bet you will get alot of info.
Old Apr 24, 2008 | 01:35 AM
LB66383's Avatar
LB66383
The dial on the passenger side of the carb is the choke adjustment. That should have no affect with the engine warm. It enriches only when the engine is cold. If the choke isn't fully open when the engine is at operating temperature, readjust it so it is.
When you say it is backfiring, do you mean it is popping back through the carburetor, or it is popping out the tailpipes??
Old Apr 24, 2008 | 01:44 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Please post in only one area
Old Apr 24, 2008 | 03:54 AM
sly vette's Avatar
sly vette
Old Apr 24, 2008 | 01:20 PM
Ward72's Avatar
Ward72
Try this web site on Rochesters:
http://www.tocmp.com/manuals/Carbs/R...ual/index.html
Old Apr 24, 2008 | 01:51 PM
panic's Avatar
panic
Some popping is even nice on a performant high comp engine and i think is not that dramatic at all, the V8 of my M3 (which is one of the most technological advanced engines on the market and with a very complicated electronics) pops when i release the throttle from 7/8.000 rpms at speed...but it doesnt back fire.
Old Apr 24, 2008 | 05:02 PM
tyancey00's Avatar
tyancey00
Ok guys,,, there have been times when you did not know things...
The dial on the side is the electric choke. Set it to be open when motor is warm and leave it. Check the timing, it will slip sometimes. Then take it to a club tech day. This is the kind of thing those guys love. Don't belong to a club, there are a lot of choices. They all have someone whou lives and breathes Chevy motors. They are all the same.. just a 350 chevy.
Old Apr 24, 2008 | 07:33 PM
Surfer69's Avatar
Surfer69
To popping!!!!
