Not your usual headlight problem
Old Apr 24, 2008 | 05:53 PM
Red70vette's Avatar
Red70vette
Default Not your usual headlight problem
My headlight vaccum system works fine. My problem is in my high beams. Low beams work fine but when I switch on the high beams the driver's side high beam doesn't work. I swapped the bulbs and the bulb is not the problem. I checked all the wiring and do not see an obvious problem.
Does anyone have some suggestions for trouble shooting this problem? As always any assistance is appreciated.
Old Apr 24, 2008 | 06:26 PM
'75's Avatar
'75
Remove the plug from the bulb and check for power and ground. Those pugs are prone to corrosion too, might try wiggling it and see if it lights up.
