shortening wiring
Old Apr 27, 2008 | 08:13 AM
talc's Avatar
talc
Default shortening wiring
have installed an aircon and when tried to replace the dash. Was going well until tried to replace screws in the dash. Found the 'bird nest' of wires wouldn't allow it to fit properly. Its the usual problem of a heap of wires some going no where. So I need to decrease the wires present. So what is the best way to cut and rejoin wires. The idea of using the wire crimp connectors is not quite what I want and a little bulky.
Old Apr 27, 2008 | 09:12 AM
corvette744's Avatar
corvette744
Cut solder and heat shrink it how i do all of mine.you can do pullups on them after ward.Just remember to put the heat shrink piece on before you reconnect the wire to solder and push it up high on the wire to not get it hot .
