headlight switch
Old Apr 30, 2008 | 11:15 AM
ace_cobra's Avatar
ace_cobra
Default headlight switch
my lights pop up and stay up when the engine is running, so i decided to trace the problem back. When testing the headlight switch, i put 20" vacuum on port 2(back) and put the gauge on port 3(front). With the switch closed it held at 20", but it also held 20" when opened When i removed the vacuum source with the switch open it held at 20", and then relased pressure when i closed the switch. Shouldnt it release the pressure when the vacuum source is on though? New switch, could it be faulty?
Old Apr 30, 2008 | 05:57 PM
Alan 71's Avatar
Alan 71
Here's the test....
**** in,block front (3) hook pump to rear (2) should hold vacuum.
Pull ****, hook pump to front (3), should not hold vacuum. Hook pump to rear (2), should hold vacuum.
Everything I know I owe to Dr. Rebuild.
Regards,
Alan
