Carb question
Old May 2, 2008 | 11:58 AM
rayluka's Avatar
rayluka
Default Carb question
Where does this connect?
Old May 2, 2008 | 12:15 PM
pacrimmat's Avatar
pacrimmat
should connect to the vapor canister located under left fender. looks like your tube is broken off tho'
Old May 2, 2008 | 12:43 PM
7T1vette's Avatar
7T1vette
I think the larger line is coming from the PCV valve; and that is where the vapor cannister ties in. If your cannister is plumbed in that way and you have vacuum going to the distributor vacuum can, just put a cap on it. Boy, I'll bet the idle 'sucks' with that port left open.
To Carb question
