Scotching off wires, how do ya'll do it?
It's everything my nightmares told me it could be......
Was this f'tard Bubba trying to kill me?!
I dearly love peaking in the dash to the gleam of copper in the afternoon sun. It really makes me sick to look at it. No wonder the tach stopped working with the ground running to one of the mounting bolts for the dash.
So.... I'm combining wiring, clipping out wiring wholesale.
Clipping off all these dash lights with the hot center leads flopping around.
Cutting out this network of poorly executed taps.
Crimping splices on wires that are twisted together.
The turn signals are those 1 wire dash light sockets mounted in the dash pad itself with a spade connector forced on the metal ground star around the bulb....... Getting sick again....
How do ya'll pinch off unused wires?
Clip and electrical tape?
Crimp caps on the ends?
Bubba hasn't emailed me back since I used the words wiring and hate in the same sentence.....
Good Luck
Steve
That said, I usually twist 'em and use shrink tube. One bubba comment -- put the tube on before you connect the wire ends! I get a case of the stupids and forget that once in while.
Worked on the dash wiring several hours. I'm basically lazy and put things off but I do get into this zen thing when I'm wiring.
I'd seen those but never used them before. I'll take a better look at them tomorrow after work.
Unless you really like chasing wires upside down 6 months down the road when something makes smoke or stops working, I'd get a good replacement from Lectric ltd. Best of luck, sometimes it's just better to buy a replacement then try to undo Bubba's handywork
Especially on something that,improperly done, can cause a fire and a total loss of your car.
that's the picture that's worth a thousand words, half of them being The F word.
soldered connections with heat shrink. after a while a heat gun is worthwhile, not only under the dash, but in the engine compartment. there's some good "economical" models out there. I have an Ungar, it's served me well for many years.
the self-vulcanizing tape comes in handy also.
I would tend to agee, if the problem is extensive enough.
