Ignition shield mounting
Old May 3, 2008 | 07:37 PM
GPGG70's Avatar
GPGG70
Default Ignition shield mounting
Before I jump into removing the bolts on the intake manifold to bolt up the ignition shield supports is there anything I should be aware of and during the installation of the bolts holding the ignition shield supports, Should I use some sort of sealer on the threads. Also looking in the manual for the torque limits on the bolts and I'm not 100% sure how much to torque up.
My vette is a 1970, small block 350/300hp stock manifold.
Thanks in advance for the info.
Old May 4, 2008 | 07:38 AM
redwingvette's Avatar
redwingvette
Yes you need thread sealer and torque the bolts to 35 if it is a cast iron intake, 25 if it is aluminum intake.
Old May 4, 2008 | 08:16 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Old May 4, 2008 | 09:42 AM
GPGG70's Avatar
GPGG70
Thank you very much for the information. I wasnt able to start the job on installing the shield yesterday due to the honey do list but got that out of the way and will be able to install today.
Old May 4, 2008 | 10:51 AM
Jud Chapin's Avatar
Jud Chapin
You're welcome.
Old May 4, 2008 | 11:15 AM
7T1vette's Avatar
7T1vette
35 ft-lbs on 1/4" trim bolts???? Sounds like a lot to me.
Old May 4, 2008 | 11:18 AM
Jud Chapin's Avatar
Jud Chapin
I believe we're talking about the rear manifold bolts that hold the ign. shielding supports in place.
Old May 4, 2008 | 02:05 PM
7T1vette's Avatar
7T1vette
If those are 3/8"-16's, 32-36 ft-lbs. is correct. [Thanks for clearing that up.]
To Ignition shield mounting
