Jamming Heat Riser Down/Open
Old May 4, 2008 | 07:52 PM
Paul L's Avatar
Paul L
Default Jamming Heat Riser Down/Open
My heat riser works free and easy but never settles in the down/open position when hot. I don't have a welding machine. How can I jam/hold it down? Some form of metal shim against the exhaust manifold?
Old May 4, 2008 | 07:55 PM
A88FXRS's Avatar
A88FXRS
Coathanger
Old May 4, 2008 | 07:58 PM
Paul L's Avatar
Paul L
Originally Posted by A88FXRS
Coathanger
Held against what? That's not a very useful reply.
Old May 4, 2008 | 08:30 PM
BarryK's Avatar
BarryK
Paul
you can use some type of metal wire, such as the previously mentioned coathanger, to wire it open all the time. You store your cars in the winter anyway so don't really need it.
Wire it against anything handy you can to wire it open, perhaps wrap the other end around one of the A.I.R tubes or anything else.
You might find it easier to just remove it ad replace it with a spacer unit or remove it, pull out the valve itself so it's always open, and reinstall it.
Old May 4, 2008 | 11:18 PM
CCrane65's Avatar
CCrane65
I used a piece of Romex wire to hold mine open. I wired the counter weight to the nearest stud.
Ran it that way for months until I decided to replace it with a bypass spacer.
cc
Old May 4, 2008 | 11:27 PM
7T1vette's Avatar
7T1vette
Sounds like the bi-metallic spring on the riser is shot. Maybe just replace it so it will work correctly.
Old May 4, 2008 | 11:53 PM
72ragtop's Avatar
72ragtop
i had wired it open by using coat hanger also. while in open position just wire to the 2 of the 3 studs on exhaust manifold, where exhaust pipe connects. this worked for me 6 yrs til i changed exhaust system
When i put new exhaust on. i dremmel cut the butterfly flaps off on the inside. thus keeping the factory look from outside.
Old May 5, 2008 | 07:22 AM
Paul L's Avatar
Paul L
That was my conclusion as well. For the moment I will try the coathanger mod.
Old May 5, 2008 | 10:25 AM
jim2527's Avatar
jim2527
I dremmeled mine as well but I went as far as removing all of the butterfly....the end result was the rod wanting to walk out. I rigged itwith a coat hanger and ordered an eliminator spacer from a vendor.
Old May 5, 2008 | 10:36 AM
stingr69's Avatar
stingr69
You can use the spacer that was originaly used on fuel injected Corvettes. It is the same size as the heat riser valve but has no butterfly or functional parts. A clean way to get rid of the valve and does no damage to the original parts. The coat hangar wire method is effective but not as "clean" - Bubba
The later Corvettes used a spring loaded riser valve that will default into the fully open mode if the hose is removed or plugged. I have the hose plugged on my '80.
-Mark.
Old May 5, 2008 | 11:14 AM
fauxrs2's Avatar
fauxrs2
Mines fully connected.....
Old May 5, 2008 | 01:55 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I wired my open but I bought a length of fine ss wire. Coat hanger would be too difficult to bend and wrap IMO.
Old May 5, 2008 | 02:00 PM
7T1vette's Avatar
7T1vette
Yes. And if you twist it up "nice and purty", it'll just look like a necessary safety wire arrangement.
Old May 5, 2008 | 07:18 PM
Paul L's Avatar
Paul L
I just put a large cir-clip/worm ring around it. It won't move.
To Jamming Heat Riser Down/Open
