Speedo Cable Tranny Fluid Leak
Old May 9, 2008 | 08:43 AM
rodb's Avatar
rodb
8th Gear
Default Speedo Cable Tranny Fluid Leak
While removing the speedo cable on my 81 Auto tranny to replace the “O” ring seal on the speedo driven gear, I removed the retainer bold then tried to unscrew the cable (big mistake, should have done the cable first.) The driven gear popped out still attached to the cable. I cannot find the retainer. Does anyone know what it looks like or where I could get one? It sure would help to know what I’m looking for.
Last edited by rodb; May 9, 2008 at 08:45 AM. Reason: Add year and transmission type
Old May 9, 2008 | 09:05 AM
TimAT's Avatar
TimAT
There is nothing that holds the driven gear in the adapter. It just slips in. There is a small seal in the cable end of the adapter that's help in with a small round wire retainer. IT goes around the shaft of the driven gear.
Old May 9, 2008 | 09:37 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
There is just the speedo assembly retainer, that bolts to the tranny, that holds the cable assembly and gear in place. Mine seems to always leaked some but a put a hair bigger o-ring in last time which seems to have helped.
Old May 9, 2008 | 10:07 AM
rodb's Avatar
rodb
8th Gear
Its the "speedo assembly retainer" that I think I'm missing. Any idea what it looks like?
Old May 9, 2008 | 10:15 AM
Jud Chapin's Avatar
Jud Chapin
It's a sort of "Y" shaped clamp that's about an inch or so long. One end has a hole in it for the bolt to go thru that attaches to the tranny and the other end is the Y portion which goes around the assembly to hold it in place.
Old May 9, 2008 | 11:23 AM
7T1vette's Avatar
7T1vette
Go to any junk yard and take one off another 'similar' GM tranny.
Old May 9, 2008 | 11:51 AM
rodb's Avatar
rodb
8th Gear
I found it wedged under the rear tranny mount! Here is what it looks like. Thanks everyone
[IMG]C:\Documents and Settings\rodney.wilson\My Documents\drawing1.gif[/IMG]
Old May 9, 2008 | 11:54 AM
Jud Chapin's Avatar
Jud Chapin
Glad you found it. BTW, your link cannot be accessed.
Old May 9, 2008 | 11:19 PM
dobroman2001's Avatar
dobroman2001
Here's what a '76 looks like:
http://s189.photobucket.com/albums/z...20replacement/
Old May 10, 2008 | 11:35 AM
MN-Brent's Avatar
MN-Brent
Mine is now leaking after I replaced the speedo cable (700R4). Same type set-up.
Question is: does replacing just the O-ring usually help, or does it also leak from the shaft bushing area, meaning you have to replace the entire assembly ($70 assembly vs $0.50 O-ring).
Appreciate any experience on that one.
Brent....
Old May 10, 2008 | 11:39 AM
Jud Chapin's Avatar
Jud Chapin
Brent....
As I mentioned above, I used a very slightly bigger o-ring than OEM's and that seemed to help.
To Speedo Cable Tranny Fluid Leak
