plugs gapping question ?
Old May 10, 2008 | 01:18 AM
canadian73's Avatar
canadian73
Default plugs gapping question ?
i,ve got an msd pro billet distributor with an msd 6al box and a matching coil from msd giving me apparently 48,000 volts . my question is what should i use in terms of spark plug gap . the engine temp is always arond 180 . the heads are aluminum and the comp. ratio is arond 9.7 to 1 and i,m using 94 octane gas ?
Old May 10, 2008 | 02:28 AM
jerrylee's Avatar
jerrylee
I think 35 should work ok.....It's been working fine for me....Just wait to see what others say.....Jerrylee///
Old May 10, 2008 | 08:22 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I just switched from Points to HEI. The factory specs for points gap was .035. For HEI for 1975 was .060, and for 76-82 was .045. My new AC R44TS were factory gapped at .045 so I installed them at that setting. At least one other forum member advised to go to at least .040
Old May 10, 2008 | 08:29 AM
Gordonm's Avatar
Gordonm
I run a MSD billit dist and a Crane HI6 box and I have been running .040 for a couple of year now. Works fine.
Old May 10, 2008 | 12:21 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
With the very high output of the MSD-6, it has absolutely no problem firing across a larger gap. Smaller gaps are only necessary for high compression ratios or for supercharged applications. Since the spark duration is so short, a longer gap lights the fire more reliably since it touches more gasoline molecules, and is especially helpful at partial throttle settings, in other words, better mileage at cruise. I've had good luck with setting the gaps to .060 and have been doing so for the last 25 years with the MSD and capacitive discharge type ignitions.
Cheers,
Larry
Old May 10, 2008 | 06:00 PM
chvet73's Avatar
chvet73
Old May 10, 2008 | 11:31 PM
canadian73's Avatar
canadian73
thank you guys . i was already running .050 but was afraid of cracking the positive electrode insulation with more .i,m going to give it a shot to .060 and see what's happening , cause it's a pain in the --- to remove some of these angled plugs , in particular that # 7 . cheers
To plugs gapping question ?
