Carb sizing and fuel efficiency
Old May 12, 2008 | 10:03 PM
Paul G's Avatar
Paul G
Default Carb sizing and fuel efficiency
I have been thinking about removing the 750 Holley off the big block and replacing it with an Edelbrock 1405, 600 CFM carb a buddy of mine has, and isnt using. The Holley has seen better days, it needs a complete overhaul. My mileage with the Holley has been absolutely horrible. (a lot of reasons for that )
My question is will my mileage go up with the smaller Eddy? Or will the power just go down with no appreciable gain in MPG? My goal here is better MPG sacrificing power if need be.
What do you guys think?
Old May 12, 2008 | 10:05 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
your mileage will go up and your top-end and acceleration will go down
Old May 13, 2008 | 12:23 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
IMHO I'd rather ration the quantity rather than the quality of my time in my shark, and I'm betting you'll likely be more disappointed by the drop in performance than by the increase in mileage, as a 600 is just way too small for any BB Corvette. I'd suggest overhauling the Holley and then putting a proper fine tune on that engine, as that may be all you really need.
BTW, the most efficient carb setup I ever had on a BB was the Tri-power (w/vacuum secondaries), which flies in the face of the smaller carb is better notion for mpg. Just my $.02...
Old May 13, 2008 | 12:50 AM
BigBlockTank's Avatar
BigBlockTank
Originally Posted by 400hp427vette
your mileage will go up and your top-end and acceleration will go POP!!!!
There, fixed it for you. A good rule of thumb for carb size is double the cubic inches, and drop down to the very next size carb. Not always an exact science, but a damn good start.
Old May 13, 2008 | 06:11 AM
Matt Gruber's Avatar
Matt Gruber
did u read my carb page?
http://community.webtv.net/MATTGRU/carb
i'd try an 800cfm 4165 double pumper with a 4 holer & no cut down center divider.
Old May 13, 2008 | 06:23 AM
7T1vette's Avatar
7T1vette
For a Corvette, the way to get fuel efficiency is to leave it parked in the garage!
Old May 13, 2008 | 09:56 AM
Jims66's Avatar
Jims66
Rebuild your 750....., tune the car, and try to keep your foot out of it unless the situation warrants it (eg. some clown in a late model Mustang is next to you at a red light !!) OR as 7T1vette suggests......, leave it in the garage for awhile. You don't want a "slow" Vette !!
Old May 13, 2008 | 10:28 AM
Roughrider's Avatar
Roughrider
I like Edelbrock carbs, but a 600 is simply too small for a big block. Either have your Holley rebuilt or find a replacement of 750-800 cfm airflow (Edelbrock, Holley, Q-Jet or Demon).
You're going to be sorely disappointed with too small a carb, but you can stay at a Holiday Inn Express!
Old May 13, 2008 | 11:10 AM
olescarb's Avatar
olescarb
One of the best carbs for fuel mileage is a q-jet, it has very small primarys so as long as you can keep your foot out of the secondarys you should get good fuel mileage. Tune the ignition spark advance and air/fuel mixture curves and you should get decent mileage.
Henry @ olescarb
Old May 13, 2008 | 12:37 PM
lars's Avatar
lars
Henry and I agree on that one. A Q-Jet, in stock or near-stock format, is actually jetted to provide pretty fair mileage, and you can get a lot of tuning and mileage efficiency out of getting your ignition curve tuned right.
Lars
Old May 13, 2008 | 05:04 PM
Paul G's Avatar
Paul G
I went for a ride with the borrowed Eddy 600. Man what a difference! No spitting, backfiring, hesitation problems or any of that. It idles smooth and accelerates nice and smoothly. Only thing is a very noticeable loss of power. I am going to borrow it for a tank full of gas and see what the mileage turns out to be. The Holley 750 was giving me around 6.5 MPG. If the Eddy 600 gets me close to 10 I may just stick with a little carb for a while.
Granted owning and driving a big block is going to be expensive, but with 91 octane over $4.25 a gallon, 6.5 mpg just has to make me stop and think twice about driving the car as much as I would like. Giving up some HP to save some fuel is the responsible thing to do for now.
Old May 13, 2008 | 05:07 PM
Paul G's Avatar
Paul G
You know, the more I think about it, wouldnt it be smart to have a little fuel efficient carb for cruise nights and car shows and all that, and have the big Holley to swap back on if we go to the track.
What are your thought on that?
Old May 13, 2008 | 05:58 PM
TheSkunkWorks
I got ~14mpg city with those 3x2 BB setups in my heavy SA which I mentioned earlier, whenever I could keep my foot out of the secondaries. Even the 1050 cfm progressive mechanical Dom could manage ~9mpg on a fairly moderate 427, so I wouldn't exactly be dancing about over 10mpg from that 600. (Note: these examples were all with 1:1 top gear manuals) Sounding more and more like you need a tune up. Food for thought...
Old May 13, 2008 | 06:30 PM
thegazman's Avatar
thegazman
Default thegazman
Lars and Henry are right. I bought a 750 Q-jet rebuilt by Jet Performance from Jegs. I installed it along with a Performer spread bore intake.I get good gas mileage, great idle, acceleration, and power when I put my foot in it and open up the rear bores. I bought their level 2, which is designed for better acceleration from off of idle.
Ken
Old May 13, 2008 | 09:03 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
If you are getting 10mpg in anything less that a ProMod race car you need to tune your carb properly. An LM-1 wideband will pay for itself in a couple of months. I got 25mpg on the highway with 550HP small block @ 80mph.
Partly because of the overdrive tranny but the carb (825 Dragrace Demon) was tuned properly. When I got my engine back after being at the dyno shop I thought I had a hole in my gas tank the way the gas gauge was moving, I thought I could see it move, I am not kidding either, I went under and took a look for a leak. Turned out the carb was waaayy to rich, when I hooked up the LM-1, tune the carb and you should see double the gas mileage
Old May 13, 2008 | 11:28 PM
sly vette's Avatar
sly vette
Henry @ olescarb
Lars
IMHO a Q-Jet is the right carb for all the issues listed above.
Old May 13, 2008 | 11:36 PM
BigBlockTank
Not to hijack, but I got my new 80508S carb today, a 750cfm 4150 I think. Put it on and it idles at 4-500 rpms, if I wanted it too (turned it back up after). My vacuum has come up from 10" to 13-14". Response is great, acceleration is fine, a great all around carb, and especially in comparison to the other one I had. Holley really fouled up with quite a few carbs. Alot of them had "bubbles" on the inside of the fuel bowls and metering plates. Very happy now, runs like a 454/365 should!!!
To Carb sizing and fuel efficiency
