blower motor resistor?
Old Jul 6, 2009 | 06:15 PM
wer2xu's Avatar
wer2xu
If this is a typical DC motor set up, the high position would bypass the resistor sending full voltage to the motor to turn max speed. There must be a connection or wire that is seperate of the resistor from the power source to the fan. Do you have a wiring diagram?
Old Jul 6, 2009 | 06:29 PM
txsugar08's Avatar
txsugar08
Originally Posted by RunningMan373
It's gotta be there,, but if i remember, the power take off point was moved on later years, don't know where to though. Best way to look for it is to find the power block, it's just a small metal screw down, directly (1/2") under the horn relay. It comes off red, goes to fuse, goes out org. Wires coming off of there go several places, on of them goes to the fuse. if it's not there, post your year and and question for it's location on forum.
designed that way. no CO.
it goes from the fuse, then into a wire harness over to the blower motor relay.
I give up!!!! cant find it.
Old Jul 6, 2009 | 06:40 PM
txsugar08's Avatar
txsugar08
I give up!!!
Old Jul 6, 2009 | 06:41 PM
txsugar08's Avatar
txsugar08
Thanks for all the help but i cant find....and now im pissed.
Old Jul 6, 2009 | 07:43 PM
txsugar08's Avatar
txsugar08
I quit!!!!!
Old Jul 5, 2012 | 09:40 PM
paglassnut's Avatar
paglassnut
2nd Gear
check the grey wire push on terminal of the AC relay, if removed it will cause no high ,but lower speeds will work
Old Jul 5, 2012 | 10:02 PM
speedreed8's Avatar
speedreed8
dont give UP, 78 is a little different from older models. orange wire goes from selector switch to high speed blower relay.and controls it, it has no inline fuse, uses the same fuse as rest of ac system.
there is a red wire on high speed blower relay that supplies power directly from starter positive terminal to the blower motor. that red wire goes through a large connector with several wires right above the right valve cover next to ac box. check that connector for corossion and power.
http://www.corvetteforum.net/c3/tune.../index16.shtml
connectors are shown at bottom of page in figure C & D c406 c403
http://www.corvetteforum.net/c3/tune...l/index8.shtml
Old Jul 5, 2012 | 10:41 PM
...Roger...'s Avatar
...Roger...
Originally Posted by txsugar08
On my 76 when I turn the AC to the highest setting, the blower stops. I have replaced the relay I have checked the blower motor resistor and dont know what the hell Im looking at. Any ideas on why the blower stop when turned to high.
The OP was about a 78 and then we switched to a 76.
Old Jul 6, 2012 | 08:07 AM
speedreed8's Avatar
speedreed8
oops, youre right Roger, didnt catch that, switched in mid stream. oh well, thanks for your input as always.
Old Feb 3, 2019 | 06:36 AM
Aussie C3's Avatar
Aussie C3
6th Gear
Default So much assistance. I'm very grateful.
Well Thanks guys! All theses years later the thread certainly helped me. The photos were GREAT!
