Why do I keep Blowing U Joints?
Old May 19, 2008 | 12:35 PM
christiscomingselah's Avatar
christiscomingselah
Cruising
Default Why do I keep Blowing U Joints?
I have a 1980 L82 that I bought about 20 years ago. It has 122,000 miles on it, and I have blown 4 U joints, and I can tell that I am about to blow a 5th. There is a clicking noise at low speeds, particularly when turning right, but also when I drive straight from a stopped position. Every blown U Joint has been in the right wheel. Also the right wheel is towed in at the top. Somebody said that it might be a bad spring causing the tow in. Is the tow in related to blowing U joints? Why is this happening? I wish I could say that it was because of all of the power from the motor, but it's not. I have replaced the yokes on both sides, as well as the trailer arms and half shafts, but that has not solved the problem. Please advise. Tom
Old May 19, 2008 | 01:07 PM
Amelio's Avatar
Amelio
I have not had this problem myself but if you are saying that your wheel is towed in or your camber is off I would imagine it would put unecessasry strain on the U-joint.
I would suggest getting a wheel alignment done and use a solid spicer U-joint unless that is what you are using. Fix what you know is wrong first (alignment) and then move forward from there.
Good luck
Old May 19, 2008 | 01:10 PM
GTR1999's Avatar
GTR1999
Maybe you have a bent flange and the joint is binding?
Old May 19, 2008 | 01:26 PM
68/70Vette's Avatar
68/70Vette
The wheel shouldn't be "towed in" at the top;i.e. cambered in. You need to get this fixed. This is ordinarily a strut rod out of adjustment and perhaps a weak spring issue.
When you had the first u joint replaced the mechanic may have bent the u-joint flange if he didn't use the correct tool when pressing the old u joint out. This flange is the that attaches to two of the arms of the u joint spider. The other arms are pressed into the half-shaft (The flange has a splined hole in it to slide onto the trailing arm half axle) The bend may not be obvious. When a new u joint is installed in the flange, the u joint should be pretty easy to move by hand and not exhibit binding.
Old May 19, 2008 | 03:46 PM
Mark Snyder's Avatar
Mark Snyder
I second the bent flange. Chased this in my younger days...
Old May 19, 2008 | 08:00 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I built a tool to keep the flange from being bent when the U-joint cups are pressed in using 1.5" thick steel....
To Why do I keep Blowing U Joints?
