welding question
Old May 19, 2008 | 04:59 PM
another-user's Avatar
another-user
Default welding question
ive never heard of this before, but a friend of my dads and my dad both have said the same thing.
what are the proper steps for safely welding the frame? they both said to keep the motor running while welding on the frame so that an arc doesnt seize the main bearings together.
any truth to this, or should i just disconnect the ground from the battery?
Old May 19, 2008 | 05:12 PM
'75's Avatar
'75
It never hurts to disconnect the ground from the battery. If you're welding on the frame, just make sure your ground clamp is on the frame too, the closer to your weld the better.
The only way it would hurt the main bearings is if you tried to ground your weld through the crankshaft.
Old May 19, 2008 | 05:18 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
No truth. The only way one could have the current go through the main bearings is to connect the ground cable to the flywheel or harmonic balancer and then weld!
Seriously, think of the circuit for electrical current flow. It will be from one cable to the other, through the electrode and the work, direction depending on polarity. As long as the engine or other items are not involved in this circuit, they'll be ok.
Old May 19, 2008 | 05:25 PM
another-user
i think the idea is that they would be on the circuit. your welding on the frame, the motor mounts are connected to the frame, and the motor is bolted to the motor mounts.
Old May 19, 2008 | 05:57 PM
vettedan's Avatar
vettedan
Old May 19, 2008 | 07:12 PM
dannyman's Avatar
dannyman
Your dad and his friend are having a little fun at your expense. Let them know the forum is backing you up!
Old May 19, 2008 | 07:57 PM
Aggitated Monkey's Avatar
Aggitated Monkey
What about wheels bearings and u-joints
Old May 19, 2008 | 10:04 PM
another-user
i wish, hes the one thats doing the welding. they both had their cars always running when they had to do any welding on the frames.
Old May 19, 2008 | 11:03 PM
chris75stingray's Avatar
chris75stingray
i weld on unibodies all the time and have never heard of this or had it happen. you can fry sensative electronics though by welding on the car close enough to them
Old May 19, 2008 | 11:52 PM
chevr0letman's Avatar
chevr0letman
Electricity never goes out of its way, its nature is to find the shortest route to complete the circuit, its not going to travel anywhere it doesnt have to. Keep your ground close to your work and you will be fine. I'm thinking superstition on their part.
Old May 20, 2008 | 09:19 AM
SH-60B's Avatar
SH-60B
I've never had any problems with welding on any car or truck. I disconnect the battery when I remember but I haven't fried any electronics even with the battery connected. I've heard of guys welding on the exhaust while the motor is running because the exhaust gasses are inert and the penetration inside the pipe will be clean, but....whatever.
Old May 20, 2008 | 09:30 AM
hugie82's Avatar
hugie82
That's an Old Skool mentality. I have heard that said on many occasions. So Don't say anything to your dad, that's the way he was schooled. But do disconnect battery. If you run your engine and weld, you may fry the module, alt, tach, ect...
Old May 20, 2008 | 10:38 AM
pacrimmat's Avatar
pacrimmat
Do disconnect the Battery
Dont know what rig you are using but reverse polarity if occurs will fry your circuitry and weld any lose mechanical fittings close to your ground clamp.
Old May 20, 2008 | 11:37 AM
Scott Marzahl's Avatar
Scott Marzahl
How many times have you seen a muffler shop leave the car running when they mig on a new exhaust system, never. This is definately an old urban legend.
Old May 20, 2008 | 06:00 PM
TCracingCA's Avatar
TCracingCA
Default I have done alot of welding and will add my story.
In working on my 1965 El Camino I put the clamps close to the work area and in doing thicker sections. Have touched the car and had current run thru me, but never anything that hurt me. Actually it reminded me of when I was in the Navy and we went down to Tijuana and there are the striped donkeys for photographs and guys running around with electrical shock boxes that if you are stupid enough, you can pay them to hook you up and get juiced. Because I was the only one that didn't, I was bothered all night until drunk enough to do it and touching the El Camino with current was less severe than that. I can't see how anything short of putting the welder tip on a bearing would ever cook those fuse them. I would think that the upholstery would smolder first.
Old May 20, 2008 | 06:46 PM
bj1k's Avatar
bj1k
No truth to it, but you can fry the alternator on some cars if you don't disconnect the ground cable.
To welding question
