Passing gear?
Old May 23, 2008 | 01:10 PM
glassman74's Avatar
glassman74
Default Passing gear?
How does the passing gear engage on my 74?
Just read thread on cowl air flow ind., and it said a sw. on
gas peddle kicks it in. Mine will not engage. If this sw. does it,
were can I get new one? In put please.
Thanks glassman74
Old May 23, 2008 | 01:38 PM
redwingvette's Avatar
redwingvette
The switch is mounted to the area above the gas pedal. The gas pedal rod pushes the switch when you push down on thwe pedal to full throttle. Both the air dam door and the TH400 downshift solenoid are then actuated. If the switch is not being made then you can try to readjust it or replace it. Make sure you have 12volts to the swich and that it is being pushed enough to activate it first. You can each up and pull it out with your finger to see if it is working before you try to replace it.
Good luck
Old May 23, 2008 | 02:31 PM
Durango_Boy's Avatar
Durango_Boy
If the switch is working then maybe look into replacing the solonoid.
Old May 23, 2008 | 05:13 PM
lars's Avatar
lars
Make sure you have a Turbo 400 first... only the TH400 uses the electric kickdown switch on the gas pedal. If you have a Turbo 350 you have a kickdown cable attached to the carb throttle lever. If the carb has been swapped, many people leave the cable off and/or misadjusted and the tranny will not kick down. There is a procedure for adjusting the kickdown cable correctly just like there is a procedure for re-setting the switch on the TH400 cars.
Old May 23, 2008 | 10:56 PM
glassman74's Avatar
glassman74
Thanks for the reply. It is a th400. Have found the sw. Will ck. it out.
glassman74
Old Dec 17, 2011 | 10:05 AM
brrujo's Avatar
brrujo
Switch is NAPA part # TKS100
Old Dec 18, 2011 | 10:01 AM
08vycpe's Avatar
08vycpe
Before you replace the switch at the top of the gas pedal rod be sure it is adjusted properly. the switch is self adjusting.
Reach up and push the tab sticking out of the switch with your thumb. Push up and toward the engine (push hard). When you hear a "snap", the switch is now in the self adjusting position. The next time you go to WOT it will self adjust and energize the cowl door solenoid and the trans kick down.
If you mess with the carb throttle linkage, gas pedal rod, etc. later on, it may get out of adjustment again. simple procedure to reset.
Old Dec 18, 2011 | 10:53 AM
mk's78's Avatar
mk's78
THIS REPLY IS FOR LARS....
Hi Lars, I just read your reply to this thread and would like to know where I can get a copy of the kickdown adjustment procedure for a TH300 auto tranny with OE Q-jet?
Mk's78 aka Mike
Old Dec 18, 2011 | 11:34 AM
BHRIG's Avatar
BHRIG
This thread is from 2008............
I don't think all persons involved will answer.......
Good Luck
Old Dec 18, 2011 | 12:27 PM
Brass Pass's Avatar
Brass Pass
08vycpe:
I just learned something I never knew, and that I can use today. Thanks for the good info.
Merry Christmas!
Old Jul 7, 2012 | 01:06 PM
scf100's Avatar
scf100
GREAT THREAD..... have same problem so will adjust the switch....thanks
Old Jul 17, 2012 | 10:32 AM
scf100's Avatar
scf100
my switch by gas pedal was bad.....very hard to find the switch but found it at a Chevelle parts house...
http://www.ss396.com/mm5/merchant.mv..._Code=KICKDOWN
To Passing gear?
