need a torque value. differ crossmember to frame
Old May 26, 2008 | 01:06 PM
another-user's Avatar
another-user
Default need a torque value. differ crossmember to frame
i cant seem to find a torque value listed in my manual for the two bolts (one on each side of the frame) that hold the diff cross member to the frame
Old May 26, 2008 | 01:43 PM
Scott Marzahl's Avatar
Scott Marzahl
The AIM says 55-65 pounds.
Old May 26, 2008 | 02:49 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
I would use the low end say 50 to 55 and some blue loctite.
Old May 26, 2008 | 03:09 PM
WayneLBurnham's Avatar
WayneLBurnham
Default Ooops. So I guess Q="until it seems they might break"
is a wee bit on the high side?
I just got through putting in the rebuilt Tom's Diff and that was my first experience with the beasties.
I was more worried the taper bushing thingies wouldn't be fully seated as I installed it and wouldn't sink further until later. I dressed all edges with a file and such and lubed it with some grease or tranny fluid just to make sure. (Yeah, prolly not rec'mndd either....) I always assumed on crucial internals such as rod caps, tranny parts, ring bolts, etc., the torque was crucial, but for external frame just monster hard with, as an earlier poster mentioned, your best friend, loctite (or hard gasket sealant if you're out...) IIRC, these were only like 1/2" Grade 5's or even less, so they are clearly just positioners, not designed to take enormous torque nor hold up half the car in of themselves. I seated them first with the cheapest impact from HF, Northern or Tractor Sup'y and then checked with a nice sized 1/2 drive ratchet.
Reminds me of a little saying: "blue for planning, green if you forget and red if you're paranoid and don't plan to be back!" (loctite colors....)
Old May 26, 2008 | 04:03 PM
stinger12's Avatar
stinger12
You should still use the correct torque values on all the fasteners for the chassis. Its the bolt's "stretch" that clamps and holds parts together. Loctite or not, every bolt should be torqued to spec. I pick and choose my values from the GM service manual. When I think a value is wrong, I use a chart like this...
http://www.morbark.com/service/belttorque.pdf
It is a general chart for different grades of fasteners.
To need a torque value. differ crossmember to frame
