Radio wiring
Old May 29, 2008 | 06:08 PM
redwingvette's Avatar
redwingvette
Default Radio wiring
Is the radio suppose to work with the key in the acc. position? Mine does not, I have to have the key in the run position.
Old May 29, 2008 | 06:26 PM
Gordonm's Avatar
Gordonm
It should work in the acc. position. Is the ignition switch adjusted right?
Old May 29, 2008 | 08:02 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
should work in acc position. if switch is adjusted right, track wiring and make sure its to the right spot.. does anything else come on in acc position?
Old May 29, 2008 | 09:37 PM
redwingvette
Not that I can tell. I really haven't had a chance to get into it yet but it has been like this ever since I have owned the car. I never worried about it but the other day I was waiting in a parking lot for someone and it brought it back to my attention. Sounds like a job for this weekend.
Old May 29, 2008 | 10:02 PM
joshtried's Avatar
joshtried
if nothing else comes on (im sure at least one other thing should) then i think you need to check the switch. maybe is not makin proper connectin back there.. good luck with it
Old May 29, 2008 | 11:50 PM
7T1vette's Avatar
7T1vette
Sounds like someone has rewired the radio from ACC to RUN wiring terminal.
Old May 30, 2008 | 12:31 AM
chvet73's Avatar
chvet73
Definetly should work on accessory. I'll bet its not hooked to the correct original wire.
To Radio wiring
