torqueing down poly diff bushing...
Old May 31, 2008 | 02:59 PM
another-user's Avatar
another-user
Default torqueing down poly diff bushing...
im trying to finish up reinstalling my diff and i dont know if i have a problem or not.
my book says to torque it down to 55-75lbs. but the bushing keeps compressing down on its self and im only geting it to 40lbs or so.
do i just keep going at this until it compresses down far enough that it hits 55-75lbs or is there something else i should be doing with poly bushings?
its for a 69.
Old May 31, 2008 | 03:04 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
For the poly you go to 40LBS
This should help. http://www.vbandp.com/instructions/h...ruct/31040.htm
Old May 31, 2008 | 03:14 PM
another-user
yup, i JUST found that a moment ago. so, the diff is now in and finished.
Old May 31, 2008 | 04:06 PM
stinger12's Avatar
stinger12
Did you end up rebuilding the differential?
Old May 31, 2008 | 04:53 PM
another-user
it was an Auburn housing so there was no rebuilding. everything looked to be in decent shape anyways. i just replaced the two snap rings on the yokes which took out all the end play on both of them. sealed it up, put two bottles of GM posi additive in, and filled it with Lucas 85-140.
To torqueing down poly diff bushing...
