Electrical Gremlins
Old Jun 1, 2008 | 10:34 PM
blckslvr79's Avatar
blckslvr79
Default Electrical Gremlins
I have a short in my 79 that kills the battery within a couple hours when the car is off. I narrowed the short down today to the courtesy lights circuit. When I pull the (courtesy light/ clock/ lighter) fuse, there is no short.
Now here is where it gets interesting...
With the fuse pulled, I was pulling the car into the garage with the driver's door open about 6 inches. All of a sudden my courtesy lights came on! With no fuse in the system!
With the car off and the fuse pulled-no courtesy lights.
With the car running and the fuse pulled-the courtesy lights come on.
In addition, when this happen...my radio went dead.
I'll start pulling fuses tomorrow to try to solve the mystery, but where should I start???? Sounds to me that maybe there is a short inside the fuse box??? Is there a way to pull the fuse box out and inspect?
Old Jun 1, 2008 | 10:52 PM
Peterbuilt's Avatar
Peterbuilt
Your on the right track, by pulling the fuse you found the bad circut, now just trace all the wires in that circut one at a time. You may have a wire touching behind the kick panel, also trace the clock wire and the lighter. Since the radio went dead you'll have the check back there too. PG.
Old Jun 1, 2008 | 11:05 PM
...Roger...'s Avatar
...Roger...
Yes you can seperate the fuse box from the bulkhead connector and look in behind it.One question -is your radio an aftermarket radio or factory?
Old Jun 1, 2008 | 11:07 PM
blckslvr79's Avatar
blckslvr79
Aftermarket.
It's run with a separate wire from one of the acc positions on the front of the fuse box with an inline fuse. Radio worked fine till I pulled the fuse for the courtesy system. I'm guessing a problem in the fuse box.
Old Jun 1, 2008 | 11:14 PM
...Roger...
If you have the delayed courtesy light system there is a delay timer box that is powered by 2 other fuses-the stop light fuse and the gauges fuse.I have seen that delay box short out and do some wierd stuff.You might want to try bypassing the delay box and see if that fixes your problem.
Old Jun 1, 2008 | 11:15 PM
wombvette's Avatar
wombvette
Pull the delay timer. 90% of the time, that is the culprit.
Old Jun 1, 2008 | 11:21 PM
blckslvr79's Avatar
blckslvr79
My delay never has worked.
Maybe it's the issue?
Where is the delay box located????
Old Jun 1, 2008 | 11:22 PM
...Roger...
The timer is behind the glove box and has 5 wires going to it-2 whites,2 blacks and a pink with black tracer.Unplug it and jumper the 2 white wires together.
Old Jun 1, 2008 | 11:30 PM
SIXFOOTER's Avatar
SIXFOOTER
thats where it gets buggered most of the time. The box will short internally and cause the lights to come on with the CTSY fuse removed and also it will kill the battery
Old Jun 2, 2008 | 12:31 AM
onaqwst's Avatar
onaqwst
Old Jun 2, 2008 | 08:49 AM
7T1vette's Avatar
7T1vette
Yep. That's the guy!! He runs around in my garage all the time....causing me to drop screws in places where they can't be retreived....taking the exact socket size I just had in my hand 3 seconds ago and making it dissapear. That's the guy!!!!
Old Jun 2, 2008 | 12:01 PM
blckslvr79's Avatar
blckslvr79
He was in my garage yesterday.
I had a ratchet in my hand and spent 15 minutes looking for a 5/8 socket.
When I gave up and couldn't find it and went to put the ratchet away, that little critter had put the 5/8 socket I was looking for on the ratchet that was in my hand!
Did I just admit that???
Old Jun 2, 2008 | 12:13 PM
7T1vette's Avatar
7T1vette
Yes, you did. And rightly so! That little 'imp' is always around when I'm working on the car (or doing anything else). I've told my wife...over and over...." It's not me!!! It's the 'gremlin'!!" She just doesn't believe me.....
Old Jun 2, 2008 | 02:50 PM
onaqwst's Avatar
onaqwst
he kept on unloosening my water hose clamps in the summer of 2007....
b
Old Jun 2, 2008 | 03:29 PM
damlie's Avatar
damlie
I've got one more quick problem for you guys to solve if you would. My passenger window was giving me problems the last few months. Sometimes the circuit seemed to just go dead and there was no juice going to the window, but then 5 mins later it would work. As of two days ago, I had it go out and not come back on. However when I push the window switch, the interior lights dim. I'm a moron when it comes to electrical stuff, so feel free to speak to me like a 6 yr old. I suppose it's possible that it is not electrical and just the window motor or something but I just don't know....
Old Jun 2, 2008 | 03:58 PM
blckslvr79's Avatar
blckslvr79
Yep.
You got Gremlins too!
Wear it like a badge of honor!
I had a similar problem last fall. Turned out to be a bad connection in the center console on the back of the switch.
The fact that your lights dim when you push the switch tells me you have power to the switch, but not enough juice to do the job. Could be a window motor going out, bad connection, partially broken wires, or even dry, dirty window gears and tracks. Time to pull your door cards out and get dirty.
Old Jun 2, 2008 | 04:29 PM
7T1vette's Avatar
7T1vette
A dirty/burnt/corroded switch contact is the most likely problem. Remove the switches and use a spray contact cleaner on them. Or, if you don't mind the expense, just replace them so you won't have the 'gremlins' any more. (At least, not in the windows...)
To Electrical Gremlins
Old Jun 2, 2008 | 05:55 PM
Oldguard 7's Avatar
Oldguard 7
Originally Posted by onaqwst
Yep, that little bastard has been around since the inception of the automobile and shows up in all models under different incarnations.
Old Jun 2, 2008 | 09:21 PM
damlie's Avatar
damlie
Thanks fellas. I had planned to rip the doors apart this weekend and take a look -- now I've got a decent idea of what to look for. One more question: how do I get to the switch contacts behind the console? (eg: do i take off the console or go up from under the dash, etc)
Old Jun 2, 2008 | 09:30 PM
7T1vette's Avatar
7T1vette
You are talking about the rear (e-brake) console, right? That is removed by taking the screws out of the sides of the unit AND [this is the killer] removing the (1) hex-head [7/16" head, I believe] that locks in the back end of the console to the rear bulkhead plate [behind the seats]. You can get to it by removing the storage tray over the jack and reaching in with your left hand to the center of the bulkhead. A 1/4" drive ratchet and socket will get it loose. Once the screws are out, lift up on the front end a bit and slide out the ribbon seal on the e-brake handle. You can pull the connectors off the backs of the switches and then remove the whole thing.
