Brake lights
Old Jun 4, 2008 | 10:04 PM
MIKL's Avatar
MIKL
Default Brake lights
When applying brakes, brake lights will work sometimes and fail to work other times. How, where and what do I check to see if there is a short or bad connection??? Any suggestions!!
Old Jun 4, 2008 | 10:11 PM
wattac2's Avatar
wattac2
First thing I'd do is check the switch under the dash. It's activated by the brake pedal. Press the pedal down and activate the switch by hand, the lights should come off and on. If not, get a meter and check the switch. I'd have to guess it's probably the switch from your description.
Old Jun 4, 2008 | 10:40 PM
Durango_Boy's Avatar
Durango_Boy
, but, also check the ground at the rear harness. It bolts to the frame on the driver's side. If that ground is weak or you have a breaking wire at the terminal, the functions could be intermittent.
Old Jun 4, 2008 | 10:41 PM
7T1vette's Avatar
7T1vette
Most likely the switch [mentioned above] on the brake pedal or a bad ground wire back at the lights.
To Brake lights
