Stoker Spark Plugs Setup??
Old Jun 7, 2008 | 10:36 AM
sam79's Avatar
sam79
Default Stoker Spark Plugs Setup??
Hello, I would be interested in the manufacturer, plug #, and gap that the forum is using in their strokers. My 388 stoker with a MSD setup is using Autolite AR3924 gapped at .45
What is your setup?
Old Jun 7, 2008 | 05:15 PM
vett us all's Avatar
vett us all
My 388 Stroker 11.1 Phase 6 Bow Tie Heads 55cc. Plugs Iridium It24 .35 Gap. Msd 6al Billet Dist 8.5mm Msd Wires.
Old Jun 7, 2008 | 05:48 PM
rclinton's Avatar
rclinton
Veteran: Marine Corps
On my 383 stroker 9.6 CR with 64cc aluminum heads, MSD Streetfire dist.Im using Autolite 5224 plugs .44 gap
Old Jun 7, 2008 | 08:12 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
383, MSD 6ALN, Pump gas Run Autolite APP 3924 .050 gap
Old Jun 7, 2008 | 10:37 PM
larrywalk's Avatar
larrywalk
With three different 406 engines, both iron and aluminum heads with CRs of 9.4 to 10.75, I've run gaps of .055 to .075. Setting the gap at .055, the gap will eventually grow larger. Even at .075, I have never had a misfire all the way to 6500 rpm, but the larger gap makes the engine run better because the MSD-6 has plenty of energy to fire the larger gaps. At partial throttle, the benefits are quite noticeable. The rationale is that a longer spark length exposes more molecules to the sparks energy.
Brand of spark plug has not made any difference but I won't run multiple ground electrode type plugs because the multiple electrodes get in the way of the flame kernel, and you don't want to put the flame out. Besides, multiple ground electrodes do NOT have a spark to each electrode - you only get one spark per firing. Multiple spark ignitions, of course, will have multiple sparks at slightly different times, but this is NOT due to multiple ground electrodes.
To Stoker Spark Plugs Setup??
