cut off during hard braking
Old Jun 10, 2008 | 06:56 PM
rebc3's Avatar
rebc3
Default cut off during hard braking
my vette cuts off if i have to brake hard. i have checked the bowl level and it is about 3/4 of the way to the top of the site glass. am i missing something?
Old Jun 10, 2008 | 08:15 PM
V77Vette's Avatar
V77Vette
you might try raising it to the top of the glass
Old Jun 10, 2008 | 08:47 PM
desi's Avatar
desi
Level should be lower than the mid point of the sight plug.
Old Jun 10, 2008 | 10:25 PM
Sayfoo's Avatar
Sayfoo
And, you may have to set the secondary bowl level even a little lower to keep the fuel from splashing over on heavy braking. And, I'm assuming you have a Holley, you can buy plastic extension tubes for the bowl vents that will also help.
Old Jun 10, 2008 | 11:15 PM
rebc3's Avatar
rebc3
no, have a demon. same thing. its really bad how this thing dies on braking. lars?
Old Jun 10, 2008 | 11:18 PM
7T1vette's Avatar
7T1vette
Do you have power brakes? Did you get rid of (or have a non-functional) vacuum reservoir? If "yes" to both questions, that might be your answer.
Old Jun 11, 2008 | 08:53 PM
rebc3's Avatar
rebc3
yes i have power brakes.
so your saying that my floats are to high? i thought they needed to be that high to STOP it from cutting off. i will try the lower setting and see what happens. are ther other things that could cause this?
Old Jun 11, 2008 | 09:06 PM
RunningMan373's Avatar
RunningMan373
I bought a 4175 Holley spread bore replacement Brand New from Summit a while ago. It did the same thing, would die on heavy braking, or in a fast U-turn, or almost die on a steep hill if you taped the brakes on the way down. Adjusted both float levels up, same thing. down- same thing. back to stock- same thing. took it off, sent it to Holley for testing and adjustment, got it back,, put it back on- same thing. Put My Rochester back on, actually increases slightly, ~50 rpm, on heavy stop braking. Now in pieces in it's box in the hall way. Couldn't find the cause. If it's a new Carb, send it back for replacement, was thinking the problem may be in the metering block.
Old Jun 11, 2008 | 11:24 PM
Sayfoo's Avatar
Sayfoo
Yes, possibly. Not sure about Demons, but aren't they simular to a Holley? When you hit the brakes hard and the nose drops, fuel from the secondary bowl could slosh into the vent, then into the carb/engine and flood it. When I bought my car, it had a spread bore holley and when I lowered the float level on the secondary side, which is towards the rear of the car, it helped the problem. The Holley Q jet replacement is different than a regular Holly, and the vent extension tubes don't fit. I went back to a Q jet and life is good.
Old Jun 12, 2008 | 10:47 PM
rebc3's Avatar
rebc3
im gonna try lowering the rear bowl tommorrow. see, i thought that gas was running away from the jets under hard braking in the front bowl. but what do i know
Old Jun 12, 2008 | 11:16 PM
joshtried's Avatar
joshtried
St. Jude Donor '08-'09-'10
sounds more like a vacuum problem.. could be the float too though i guess. good luck finding the culprit
Old Jun 12, 2008 | 11:36 PM
7T1vette's Avatar
7T1vette
With a "closed" throttle and actuating the power brakes, if you have no vacuum reservoir to provide vacuum "volume", the vacuum brake servo probably changes the vacuum level of the engine and alters the timing...maybe enough to kill it.
Old Jun 13, 2008 | 02:14 AM
RunningMan373
Interesting idea, but that would mean stepping on the brakes at Any Time would kill the motor. If his problem is like mine, when standing still, ideling, stomp on the brakes- not a change, only when the car is moving at idel.
Old Jun 13, 2008 | 03:16 PM
rebc3's Avatar
rebc3
the brakes get their vac from under the carb, so it makes little difference if your closed or not. my vette doesnt have a vac cannister other than the big pipe thing in the front, under the lights
Old Jun 13, 2008 | 04:15 PM
GaryS's Avatar
GaryS
How come neither the OP or responders have mentioned the car, the engine, or the carb? What year, engine, carb, and mods have you done to the car?
Old Jun 14, 2008 | 01:23 AM
rebc3's Avatar
rebc3
78
383 w/ 525 in. lift cam, world products heads
demon 850 double pump
5 speed
Old Jun 14, 2008 | 08:26 AM
PRNDL's Avatar
PRNDL
Just one thing to rule out before you go tearing into the carb:
Make sure your battery connections are tight and clean!
My car was "dying" on hard braking and I learned (the hard way) that my battery connections were bad and the battery wasn't held down properly so the darn thing was shifting under hard braking. The problem became obvious when driving at night. Hit the brakes and the lights went out.
Old Jun 14, 2008 | 05:37 PM
rebc3's Avatar
rebc3
no, i dont think so. you can take a battery out of the car completly once its been started. you had a bad alternator and were running off of battery alone
Old Jun 14, 2008 | 07:32 PM
PeteZO6's Avatar
PeteZO6
Holley makes these things called "Fuel Bowl Vent Baffle/Whistle" p/n 26-40. http://www.holley.com/26-40.asp
IF your problem is caused by the secondary bowl fuel sloshing out the vent and down the secondary barrels, this part might be helpful That's assuming it will fit a Demon carb too.
My 4150 has them on both primary and secondary bowls from the factory.
Hope this helps,
Pete
To cut off during hard braking
