air damn question
Old Jun 10, 2008 | 09:17 PM
BigEarl's Avatar
BigEarl
Default air damn question
Here's why I'm running hot on the highway. I know that I need to get it pulled down, but there's no way to get it pulled below the bracket(red arrow). I can bend the other bracket (green arrow) but the red one isn't moving. Is this some sort of bubba modification? If I unbolt the damn will I be able to move it to where it needs to be and then be able to tighten it back up? FWIW, I pushed up the damn up a little to get a good pic. The painted portion of the dam gets hung right where the brackets meet(yellow). Even if I got it over the "hump" it still doesn't seem like it would go all the way down .
Old Jun 10, 2008 | 09:31 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
I had the same problem.It can be pryed down,it will flex backwards then pop in but BE CAREFULL. The best way I got it down was push it back and down from the center
Good luck
Old Jun 10, 2008 | 10:10 PM
BigEarl's Avatar
BigEarl
Thanks Douglas. So the main bracket(red) is where it's supposed to be? Seems like there would be a lot of prying to do since it looks like it would need to come back around an inch.
Old Jun 10, 2008 | 10:41 PM
Douglas Mariani
Pro Mechanic
Don't worry it will flex back and down. It will rest back in place where the Yellow arrow is
Old Jun 10, 2008 | 11:35 PM
BigEarl's Avatar
BigEarl
You mean green arrow ? The yellow is where it is getting hung up.
Old Jun 11, 2008 | 10:08 AM
BigEarl's Avatar
BigEarl
Does anybody have a pic they can post or confirm that it is supposed to fit on top of the bracket with green arrow? As always, thanks!
Old Jun 11, 2008 | 11:03 AM
Douglas Mariani
Pro Mechanic
Sorry Earl I ment the Green arrow. Heres some pics of mine
To air damn question
