I need help. My top radiator hose collapses and expands so it looks like a snake ate a soccer ball. What could be causing that? The thermostat?
Also what temporature should the car run at?
Sounds like you are building up pressure in system. Top hose is return.
When they get old, they get soft. If you squeeze it you can tell it.
My 74 runs at 190/200 all the time with a 180 thermostat and a 16#
rad cap and I live in the Hi desert of Ca. I would replace both hoses(wire in lower one) and thermostat. Cheep fix. Also check your flow in rad.
Putting a lower temp thermostat does not help the car run cooler...it only makes it take a little longer to reach its normal operating temperature. The thermostat provides a minimum temperature...it doesn't cap the temperature.
If it overheats with a 180 or 195 degree thermostat, it still will with a 160 degree 'stat. As I said, it just takes a little longer to do so. The solution is to find out the root cause of running too hot and address that.
Also try replacing the radiator cap - it is designed to let coolant from the recovery tank return into the radiator when the engine cools and pulls a vacuum in the cooling system. If it is blocked, the negative pressure in the cooling system any cause the hose to collapse as the engine cools hours later.
On the other hand, if it collapses while the engine is running, that would indicate blockage in the engine which lets the water pump suction collapse a bad upper radiator hose (likely a thermostat problem). In any event, replace those hoses, the thermostat, and the cap.
