I have a '69 coupe and I'm just about to put the body back on the frame. What material should I use underneath the body in the tunnel area where the original silver backed insulation used to be? I still have the clips under there and can reuse them to attach it.
I know I can buy it from one of the parts houses, but isn't there something I could buy at Lowes or home depot that would be better than the material they used there 40 years ago? I am not doing a completely original restoration - more of a resto-mod project.
I'm shooting off the hip, but if you have any local marine and boat stores they might sell engine bay insulation for the bays int he back of the boat. It would be weather proof, and heat resistant. Maybe something to look into?
That might be a real good idea Matt - and believe it or not, AZ is a huge boating state.
The original material is a thick foil back on a thin layer of fiberglass. The foil is thick enough to hold its shape. While you are shielding the tunnel, one of those noodles for the swimming pool makes a good seal over the top of the bell housing to the body when you drop it back on.
Or, considering that this will be the last time that needs to be addressed for the next 20 years...and considering all the money you've spent to make the car as nice as it is....you could 'pop' for replacement components and do it right.
I replaced mine a while back. The original was toast. I bought an aftermarket one and it fit perfectly. I wish I would have done more heat relief in the tunnel area before installing tranny. The bell housing collar (using a noodle thingy) make a big difference in heat coming through the tunnel but the trans and exh. still heat the tunnel good. I did use the heat barrier under the carpet but it still get warm.
I'll be dropping the body back onto my '76 chassis before long - what was original on these cars? I installed a foil-covered tunnel insulator above the transmission years ago, but I got the feeling that was an Ecklers aftermarket component.
I have no issue using a replacement, but my question was if there is something that would be better, since we've covered 40 years since the original design.
I am not looking for the cheap route, rather the BEST route to help keep heat out of the car in this area.
Your first decision is whether to put anything there or not. If you have a lot of stopped/idle conditions during your driving, you might not want to put the foam collar at the front of the tunnel. That tends to block airflow when at idle. But if most of your driving is at 30mph+, you will get plenty of airflow from under the car to cool the tranny area...and the collar will prevent engine compartment heat from passing the tranny also. The foil heat shield is a good idea in any event, as it will limit the heat getting into the interior via the trans. tunnel. With anything you do underneath, you need to put some heat insulation (with foil to reflect radiated heat) under the carpeting. I used Reflectix as it is a decent HEAT insulator and foil backed...and it is inexpensive plus easy to install. Others will tell you to use more expensive stuff. But be aware that Dynamat and similar products are sound deadeners, and are not marketed as heat insulation.
I've read that adding a product like lizard skin in addition to the parts you recommend, will create a significant heat barrier as well as a sound insulator.
Sorry for the hijack, But would like to know if I can remove my old insulation and install a new tunnel with the body on and with a Auto transmission.
What kind of rivets are the type for the tunnel called and is there a special tool to install. They dont look like pop rivets. How do they hold the tunnel on.
Thanks for any info.
If your '70 is like my '68, you cannot replace the tunnel insulation with the tranny in and the body on the car. The insulation is held in place by clips which are riveted to the body. The clips have points which pierce the insulation and then are bent over to hold the insulation in place. I replaced the insulation on my '68 several years ago and it made a huge difference in cabin heat. Unless the clips are broken or missing, there is no need to replace them.
Also, if you pull the tranny to do the insulation, you should also consider replacing the postive battery cable as it runs through the tranny tunnel.
Thank you for the information. The tunnel insulation is still the original tunnel& insulation and is getting loose. starting to sag down onto the driveshaft. I'll find a way to get it back up rather then drop the tranny.
Thanks, Again.
Thermo Tec has a product I was going to use. That combined with a foam collar should work wonders. I also double dynomated my interior. Still not perfect yet. Transmission tunnel next!
Quick update - I found a product made by DEI - it is sold through Summit, amongst other distributors. It's not cheap, about $115 for a 48" x 42" sheet. I bought 2 which means I have plenty of extra for other areas where I intent to apply it over my homemade lizard skin concoction ( http://forums.corvetteforum.com/show....php?t=1790043 )
Here is a link to what I used. http://store.summitracing.com/egnsea...10060&D=310060
It's got a really great adhesive on the back side and is embossed aluminum on the front. I cut it with really heavy duty sissors (like shears almost).
To BenUK, no your 76 did not use the tunnel insulation. Chevy went to steel floors in 76 because of the heat from the converter and eliminated the insulater. The foam collar was used on all 68-79's.
To GPGG70, people have been known to sneak an insulater in without dropping the trans. If you remove the shifter (or cable with an auto) I think it can be worked into place. I know people have said that it can be done by cutting a slot to clear the shifter, too?
